GLE COUPE grill replacement, do I have to remove the bumper?
There are two very deeply located bolts holding the fenders attached to the front that you need to reach to from the wheel wells. Moreover, there are plastic slide clips / pins there too.
It's an all-day job if you are not mechanically inclined and you need a lot of patience. You may want to check if a wrap is possible instead.
