Brake Fluid Replacement Procedure
Anybody got a procedure for doing this on the V167? Has anybody done it?
I have the 331.0 MB fluid ready to go any I'm wondering if a pressure bleeder is a must or can it be done with vacuum at the wheels, or even the old fashioned 2-person pedal push method.
Thank you.
Thank you.
Thank you.
Thank you.
The procedure is fairly standard on most vehicles. I used the cannister method when I did the brake service about 6 months ago. I posted some notes on the forum at https://mbworld.org/forums/g-class-w...d-service.html
SN1250 (04-11-2024)
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
Received 3,977 Likes
2017 GLE350 4MATIC
Use the DIY in my sig. Very easy procedure for all German cars.
Received 1,628 Likes
'21 AMG53 wDPP & ARC, 19 GLC300 - Former- 10&14 ML BlueTecs, 20 GLE450 E-ABC, 15 Cayenne D, 17 Macan
I quit doing the vacuum method years ago, because too often it doesn't bleed properly. The vacuum "deconsolidates" air bubbles, making them cling to interior surfaces, instead of consolidating them, pumping them out as bigger bubbles.
In other words, it works okay if you don't have any air in the lines. But if you do, you need a pressure bleeder to do a complete job.
Now I use a Motive Products - 0100 European Power Brake Bleeder Kit https://a.co/d/7ywTFbT
The whole process is easier with pressure than with vacuum in most cases. And more reliable.
