2017 GLE43 - radiator hose leaking again?
I have a 2017 GLE43 (83,000 miles) that I’ve had since day one. It’s been a great vehicle up until recently. The motor mounts / trans mount failed, a vacuum line on the oil separator leaked and a airmatic strut went bad.
my most recent issue was a upper mount leaking on the radiator. The radiator was replaced and it ran fine for a few weeks. Then the upper radiator hose started to leak where it connects to the radiator. Replaced the hose and it was fine for a few days. Now it’s leaking again. All parts have been OEM from the dealer.
anyone had this issues with the upper radiator hose leaking? I’m not sure if I should replace the hose and radiator again under warranty (parts are covered / labor isn’t). Thought I’d ask incase others have had the same issue and have a solution.
