E Class wheels on a GLE?
Old Jul 6, 2024 | 08:43 AM
Bigcitydallas's Avatar
2021 F150 Limited
I’m a little bit wheel illiterate but I like the 21” multispoke wheels on the new E class. I have a GLE on order with the GLE 21” multispoke wheels. I assume these aren’t the same size and can’t be swapped?
Attached ​pic is of the E class wheel.
Old Jul 23, 2024 | 06:08 PM
2021 F150 Limited
Bump
Old Jul 24, 2024 | 09:29 PM
Elvisfan0108's Avatar
2021 c300 Cab. Arrived 7/28/21 . 24 GLE 450e.
why don’t you look at MBUSA and see if they look the same. Is the difference enough to justify the extra cost?
Old Jul 25, 2024 | 09:24 AM
2021 F150 Limited
It’s not a matter of whether they look the same, they’re not. I’m asking if the sizing of the 21” E class wheels are the same size as the 21” GLE wheels and could be swapped.
Old Jul 25, 2024 | 10:40 AM
Kevink15's Avatar
2016 C450, 2020 GLE350
I highly doubt it. SUV's will have a different offset due to it being a larger vehicle.
Old Jul 25, 2024 | 10:47 AM
2021 F150 Limited
This is what I assumed too but wasn’t sure.
Old Jul 25, 2024 | 12:04 PM
GregW / Oregon's Avatar
2020 GLE 450; 2023 BMW M2 Coupe
E-Class wheels on GLE
Here are the specs;
E-Class
GLE
The closest comparison for width and offset are the 20" GLE wheels, The E-Class fronts are 1/2" (12.7mm) narrower with a +21.5mm difference in offset; net result is they will be recessed about 15mm further. This might be cured with spacers, but the narrow width will not really accept a tire that would look suitable on the GLE, although the 19" option uses 255 width tires, so not out of the question. The rears are 1/2" wider, with a -7mm difference in offset. The net result is they will be pretty close to the GLE's in terms of fitment.
Bottom line is you can make them work, but if you are not conversant in wheel specs you need to seek expert advice.
Old Jul 25, 2024 | 01:50 PM
wildta's Avatar
GLE 580
I would also assume they have different load ratings with a GLE being at least a half ton heavier.
Old Jul 26, 2024 | 11:08 AM
Wheel load
Should not be a factor.
Old Jul 26, 2024 | 01:09 PM
wildta's Avatar
GLE 580
You're probably right. Maybe it would matter more if they came from a C class.
Old Jul 26, 2024 | 04:03 PM
de31p5's Avatar
GLE53
If I liked those wheels, I'd get the GLE equivalent in the 53 AMG line. Not exactly the same but closer in style.
