Ceramic Coating Gone Bad
The reload spray will last a good 3-4 months depending on how you wash your vehicle. When you see it starting to not beed like crazy that is the cue to re-apply to maintain that coating. It will only cost you $80 for a 1 liter which will last you YEARS. So spray as much as you want VS throwing thousands of $$ on a coating that you still need to maintain.
The coating is just like any other paint protection, its just more durable. You can do it yourself in a few hours with $100 worth of product, the cost is in the prep and the paint correction etc. The cost detailers charge for it is totally insane.
Most people also think the coating has failed when it hasn't. There are imbedded contaminants there that are masking the hydrophobic properties, a clay and chemical decontamination and the coating is still there and performing.
$8,000 is expensive to have the whole car done in PPF, let alone a ceramic coating. $1,800 is not unusual, $8,000 is insane.
I have ceramic coated the last 4 cars I have had too, it’s no big deal at all. Most new coatings don’t require two coats and applying the coating is wipe on wipe off. All the effort is in the prep, and if the car is new and doesn’t need any paint correction it’s easy peasy.
Do you agree?
After all, claying is kind of like a mini polish, and I only consider polishing as a last resort.
I generally enjoy maintaining the finish on my cars, but having to use a ladder takes a lot of the fun out of it. I'm taking the easy way out now. I'm not spritzing with a touch up after every wash, for instance.
But I'm getting to the point where I need to clay or decontaminate the car. My initial ceramic coating is doing pretty well at 3 1/2 years, even after more than its share of tunnel car washes.
Do you agree?
I would use DIY Detail's iron remover and their clay towel. You can use the iron remover as the clay lube, that combination will not abrade the coating. They're sold out if the iron remover right now but I have the clay towel and its excellent:
https://diydetail.com/collections/de...s/iron-remover
https://diydetail.com/collections/de...ade-clay-towel
I feel you about the ladder! On the Pacifica I just ignore the roof since I cant see it lol
