I’m currently driving a 2022 GLE 350, and I’ve been considering upgrading the wheels. I’ve come across a set of wheels from a 2022 GLS and was wondering if they would fit on my GLE. My GLE is equipped with 19-inch wheels right now, and I’m specifically looking at upgrading to larger, staggered wheels like the 21-inch setup that the GLS offers.
Before I pull the trigger, does anyone know if the bolt pattern, offset, and overall fitment between these two models are compatible? Has anyone here made a similar swap, and are there any potential issues I should be aware of (clearance, ride)
Details of the wheels i am planning to purchase.
Front: A1674015100 10J et 62.6Rear: A1674015300 11J et 55
The front and rear offsets are different for GLE vs GLS. Below are the factory offsets for my 21” set for a GLE450.Originally Posted by gle2023us
It’s not a massive difference - but depending on your expectations for staggered tire fit, they may not fit the same as they do on a GLS.
Front Wheels:
- Part Number: A167 401 0300
- Offset: 10Jx21 H2-N ET54
- Tire: 275/45R21 (107H)
Rear Wheels:
- Part Number: A167 401 1100
- Offset: 11Jx21 H2-N ET49
- Tire: 315/40R21 (111H)
Front Wheels:
Rear Wheels:
Given the difference in offsets between the GLE and GLS, what kind of issues could I run into if I go ahead with fitting the GLS wheels on my GLE? Specifically:Originally Posted by OldMerc94
The front and rear offsets are different for GLE vs GLS. Below are the factory offsets for my 21” set for a GLE450.It’s not a massive difference - but depending on your expectations for staggered tire fit, they may not fit the same as they do on a GLS.
Front Wheels:
Rear Wheels:
Could there be any rubbing on the fender liners or suspension components, especially when turning or under load?
Will the difference in offsets affect the handling, especially with the staggered setup?
Would I need spacers or any other modifications to make the GLS wheels fit properly?
Just want to be sure I don’t run into any surprises down the road. Appreciate the insights!
wildta
close
- Join DateJan 2023
iTrader Positive Feedback0
iTrader Feedback Score(0)
- Vehicle(s) I driveGLE 580
Liked:1,203 Times in 887 Posts
Quote:
For future reference, try this site to research oem wheel offsets:Originally Posted by gle2023us
Given the difference in offsets between the GLE and GLS, what kind of issues could I run into if I go ahead with fitting the GLS wheels on my GLE? https://www.wheel-size.com/
You do not need any modifications, there will not be any issues or rubbing and nothing will be broken.Originally Posted by gle2023us
Given the difference in offsets between the GLE and GLS, what kind of issues could I run into if I go ahead with fitting the GLS wheels on my GLE? Specifically:Could there be any rubbing on the fender liners or suspension components, especially when turning or under load?
You are changing out from your current standard wheels to different wheels so to ride and feel will be different.
And I assume you know that going up in wheel size the ride comfort will be less than what you have now.
