On a 2021 GLE Coupe, when using the lift gate switch in the driver’s door, is it supposed to be able to raise and lower with the engine off? Mine will raise when engine off but not lower, I have to start the engine. Is this normal? Thanks
Elvisfan0108
close
- Join DateMay 2018
- LocationIllinois
iTrader Positive Feedback0
iTrader Feedback Score(0)
- Vehicle(s) I drive2021 c300 Cab. Arrived 7/28/21 . 24 GLE 450e.
Liked:300 Times in 253 Posts
Quote:
I believe it’s a safety thing. Originally Posted by PNBLWZD
W205C43PFL
close
- Join DateDec 2019
Liked:6,275 Times in 5,447 Posts
Quote:
Does it still do it when you put the vehicle in accessory mode? (so press the ignition button twice with foot off the brake)Originally Posted by PNBLWZD
wildta
close
- Join DateJan 2023
- Vehicle(s) I driveGLE 580
Liked:1,201 Times in 886 Posts
Are you holding the button the entire time? You have to press the button for the entire duration of the door closing.
Yes have tried holding down the button and gate doesn’t go down. Haven’t tried acc position. Buttons on the lift gate itself will lower it engine off or on.
Can’t remember if it was always this way or something wrong
W205C43PFL
close
- Join DateDec 2019
Try acc and see if it changes anything still better than having to turn on the engine.Originally Posted by PNBLWZD
Yes have tried holding down the button and gate doesn’t go down. Haven’t tried acc position. Buttons on the lift gate itself will lower it engine off or on.Can’t remember if it was always this way or something wrong
