Gle 53 transmission oil temp
Old Aug 21, 2025 | 06:45 PM
a_fltaa's Avatar
2022 GLE 53 Coupe
I have a 2022 GLE 53 and the transmission temp doesn’t get up to normal levels quickly although its above 40°C 100°F where I live. It only reaches 80°C 175°F after 15 or more minutes of driving. It annoys me because I want to drive in sport mode and aggressive but can’t until it reaches good temp. Any advice is appreciated!
Old Aug 21, 2025 | 11:37 PM
W205C43PFL's Avatar
That seems like a normal behaviour for MBs. It is the same with my C 43, MB uses a specific fluid that doesn't heat up quickly to prevent overheat but as a result, it does not heat up quickly from cold either.
Old Aug 22, 2025 | 10:18 AM
Sparky66's Avatar
W167 2021 GLE63S, W223 2022 S580
Trans temp
I would be more concerned that the engine oil (and all engine related components) are at operating temperature before "spirited" driving.
Old Aug 22, 2025 | 01:18 PM
a_fltaa's Avatar
2022 GLE 53 Coupe
Of course, but engine oil gets to normal temps in a couple minutes so it isn’t an issue. Are you saying I don't have to wait for the trans oil temp to start to have fun?
Old Aug 22, 2025 | 01:33 PM
superswiss's Avatar
2019 C63CS
The transmission is at operating temperature at about 120F. You don't have to wait till it gets closer to 180F. Keep the temp display up and once the drivetrain shows white, you are at operating temperature. Take it easy while either the engine or transmission still shows in blue.
Old Aug 22, 2025 | 01:43 PM
a_fltaa's Avatar
2022 GLE 53 Coupe
Thanks for the insight!
Old Aug 22, 2025 | 06:56 PM
W205C43PFL's Avatar
Kind of glad MB shows transmission temperature, for some reason I heard bmw doesn't.
