Why does Easy Entry/Exit keep getting reset?
Old Dec 20, 2025 | 03:13 PM
Involute's Avatar
2025 GLE 580, 2015 ML400
The Easy Entry/Exit feature on my 2025 GLE580 will work for a day or two and then get reset to off. Is anybody else having this problem? Any ideas what might be causing it?
Old Dec 21, 2025 | 06:28 AM
dthzo's Avatar
GLE 350de 2025
[QUOTE=Involute;9246179]La fonction d'entrée/sortie facile de mon GLE580 de 2025 fonctionne pendant un jour ou deux, puis se désactive. Quelqu'un d'autre rencontre-t-il ce problème ? Avez-vous une idée de ce qui pourrait le provoquer ?[/QUOTE
Same problem without any explanation or solution. Gle 2025
Old Dec 22, 2025 | 12:16 AM
Elvisfan0108's Avatar
2021 c300 Cab. Arrived 7/28/21 . 24 GLE 450e.
it happens to me. The software isn’t done yet. Sometimes the steering wheel moves into position before I start the car. Various other things happen. Hopefully someday it will be right.
Old Dec 22, 2025 | 12:29 AM
jmanGLE's Avatar
You guys using different profiles?
It only happens to me when another profile was used before me, same with folding mirrors and other settings.
Old Dec 22, 2025 | 12:35 AM
Involute's Avatar
Hmm. Good point. My wife uses my car on rare occasions and logs into her own profile when she does so. I'll reload mine the next time I drive the car. The reset was an issue after her most recent use (which is what triggered my post), but I don't recall if there was a correlation with past uses. I don't think so, but I'll just have to pay closer attention. Thanks for raising the issue.
Old Dec 22, 2025 | 11:24 AM
jmanGLE's Avatar
You can also add that to her profile and then it should be seamless.
Old Dec 22, 2025 | 03:00 PM
We switch drivers a lot. It doesn’t always happen. Sometimes it could be months when the easy exit and entrance could be turned off.
Old Jun 6, 2026 | 03:21 PM
tscannie's Avatar
I have a 2025 GLE 350. Has the same issue. I followed the manual's solution of making sure it was set the same in all profiles. When that didn't solve it I went to the dealer at it"s first service. They said MB instructed them to do a reset of the function. By the time I got home and the car sat, I had to reset it to ON twice. State inspection needed in July, I will go to another dealer and see their approach.
