Agonizing experience with 2025 GLE450e PHEV
Now, as a business owner and as someone who deals with the general population day in and day out...If I owned a gas station I want you on my property for no more than 15 minutes. Come, get your gas, buy a drink, go pee....leave. I would not want folks sitting there for an hour expecting me to have free WiFi a clean bathroom (two times) and what ever other thing. For that? Go use the stations at Target and wander the store while you charge.
I dont want one because we do not need folks around for that long.
- chargers can be a source of revenue
- the charge rate can be set to increase each 30 minutes to entice shorter time charging
- chargers can be installed and owned by a network that pays you rent
- high speed chargers that can charge 80% in 15 minutes earn much higher rates and are in high demand
- chargers can be a source of revenue - If that was the case, why would more business owners (such as myself) install them? More over, why does the Govt need to pressure a person like me - who is opening a MEDICAL OFFICE need to have some kind of pressure to install a freaking EV charger?
- the charge rate can be set to increase each 30 minutes to entice shorter time charging - 30min? In that time I can fill my RV and be
- chargers can be installed and owned by a network that pays you rent - could not be less interested. Last thing we need is folks at our front desk complaining on how our charger is the wrong brand and does not work with their car....I have seen this more than once at hotels.
- high speed chargers that can charge 80% in 15 minutes earn much higher rates and are in high demand - Hell, the city was not happy about how much voltage I need...then they want me to add a freaking charger for our local COAL POWERED "Eco-Friendly" cars?
- that said, the government should NOT pressure but build a beneficial business case, including incentives. Obviously without a biz case you should decline
- you can fill your RV in less than 30 minutes, how is that relevant? EV charging can be done at different rates. You can’t have gasoline refill at home or at businesses smaller than a Costco.
- When you look into charger networks there is no wrong brand. They can charge all vehicles. You can also put a sign on the charger that it is an independent business, call 1800xxx for assistance
- If the city is unwilling to support your power needs then it has no say on EV chargers. Time to advocate for coal generation replacement since even without EV charging you business, home and daily life is spewing coal. Burning coal releases particulate matter (soot), sulfur dioxide (acid rain), nitrogen oxides (smog), and mercury (neurotoxin). It causes more premature deaths per unit of energy produced than any other source.
that said I absolutely agree with you and it is a shame the United States does not refocus more of our energies on to nuclear power as opposed to some of the other delusional options out there.
Coal saved the East Coast last month, and prevented many deaths.
Plus it's affordable, as an already installed base.
One of the things I find interesting is real time data of how much "clean" electricity my house actually uses. You always hear the pundits promoting how much of our electricity is renewable. Problem is they never factor in the seasonal and weather issues and sun not shining at night when most people use electricity at home, charging their EVs over night. My utility provides this data and I can see it in the Apple Home app. For example here is last week. All of 27% of the electricity I actually used was clean. My annual average is not much better at about 34%. Even if I had solar panels on my roof. What's coming out of the wall is the same for everybody. There's only one grid in a given area. Only exception is if you have a home battery and can power your home with the energy from your panels directly, but even then, in the winter that usually isn't enough. Would need a much bigger battery.
An effective, durable and cost efficient energy system is not one type of generation. It is complex portfolio of technologies fit together and optimized for the location and its population size, weather, an other factors. Some places have more sunshine, some have more wind, some have water flow, some have reservoirs of water that can store pumped energy. No utility uses only solar or only wind or only nuclear or only coal or natural gas. The blend keeps changing as technology and costs change. Sometimes it gets out of whack when the wrong incentives are used. But it is all headed in the direction of less coal and natural gas in the long run.
Nuclear costs 3 to 4 X solar or wind per Mwh. Solar power costs have dropped 90% since 2009 and continue to drop.
A nuclear plant takes 15 years to build while a solar farm can be online in 1 year.
For these and other reasons utilities use a variety of power generation methods in combination. Using power sources in a complimentary way has gotten more sophisticated over time.
And then I'll add: unless we consider the costs from Cradle to the Grave, we're not considering the total cost.
Solution for any location tailored to its features and the available technologies. Driven by cost efficiency and power supply stability.
