I recently picked up a CPO 2022 GLE 450 (M256) and I’m planning to handle most routine maintenance myself (engine oil, fluids including transmission service, spark plugs, etc.). I’d like to buy a diagnostic tool that’s a good match for this chassis and can do more than just generic OBD.
What I’m hoping to do:
- Read/clear stored + pending codes across all modules (not just powertrain)
- View live data / freeze frame where available
- Run common service functions (reset service interval, electronic parking brake service mode, battery registration / adaptations if needed, etc.)
- Ideally access Mercedes-specific data like “actual values,” basic adaptations, and guided tests (if realistic outside dealer tools)
Questions:
1) What tools are you all using successfully on V167/M256?
2) Any “don’t waste your money” options that don’t actually reach the MB modules on newer chassis?
3) If you had to buy one setup today (hardware + software), what would you choose and why?
Budget-wise I’m flexible - I’d rather buy once/cry once than end up with something that only does generic OBD-II.
Questions:
mikapen
close
- Join DateOct 2009
- LocationColorado
iTrader Positive Feedback0
iTrader Feedback Score(0)
- Vehicle(s) I drive'21 AMG53 wDPP & ARC, 19 GLC300 - Former-03 C240,2 ML BlueTecs,20 GLE450 E-ABC,15 Cayenne D,17 Macan
Liked:2,178 Times in 1,638 Posts
This has gotten a good set of reviews in the past year or two.
Lifetime subscription to Mercedes products included.
https://a.co/d/0UjQXaS
Questions:
Take a look at what most here use. The banner is at the top of this page. Good luck!Originally Posted by notlimahrelyt
I recently picked up a CPO 2022 GLE 450 (M256) and I’m planning to handle most routine maintenance myself (engine oil, fluids including transmission service, spark plugs, etc.). I’d like to buy a diagnostic tool that’s a good match for this chassis and can do more than just generic OBD.What I’m hoping to do:
Questions:
Quote:
the banners rotate and are targeted.. so I’m just seeing a Wall Street journal ad. Originally Posted by UltraSpeed
trigital
close
- Join DateDec 2011
- LocationSpain UTC/GMT +2 hours
- Vehicle(s) I driveW213 All-terrain
Liked:475 Times in 402 Posts
Questions:
If you have enough time to do the job step by step reading very simple instruction doubled with pictures and schematics, you can buy a 15$ Openport Interface and you can pay 40-50$ for Xentry Diagnostic PT from any seller. Rest is folklore.Originally Posted by notlimahrelyt
Questions:
I just did AMG skins for Cluster, Performance variants and Facelift Headlight's on a non-Facelift w167 with all functions active with Aliexpress Openport.
Here on forum, you can find a lot of detailed tutorials about using j2534 pass-thru interface if you can filter the banned leachers that tells that the tutorials is not good after they listed on their websites.
Also you can use professional service from our sponsors like @EleBest or @rjautomotive
