Blank dashboard
Old Apr 29, 2026 | 09:59 PM
GLE450Owner's Avatar
GLE 450
Blank dashboard
2026 GLE 450 acquired with 20 miles.
3000 miles, 4 months owned.
Today - driven 10 miles to shopping center.
Parked 30 min. Started the car and within seconds, the glass dashboard goes blank. Still displays warnings such as start/stop, brake and gear setting. No tach, no speedometer, no tank level.
Adjacent infotainment display lit fine.
Shut off and on several times to no avail.
Called MB Customer Support - no help, just drive or tow to dealer. And I am 900 miles from home.
Drove 10 miles to the location I am staying on this trip with blank dashboard. Parked and locked. Wait a few seconds. Unlock, start the engine and the dashboard is lit and revived.
So it goes in the age of glass cockpits. This time maybe a transient fluke, but if it fails hard, a major disruption of vehicle use.
Old Apr 29, 2026 | 11:08 PM
vincheung's Avatar
S63, GLE580, BV250
It’s happened to me once or twice in years of ownership. I assumed it was due to a software update or glitch when booting up. From my understanding, after a little while (don’t know the timeframe) the modules reboot completely and the blank screen glitch is resolved. A dealer visit won’t do much for it, they’re just rebooting.
In my case it was a completely blank screen, no cabin turn signal noise (was working though), parked overnight and resolved in the AM. If you want to force a hard reset, move the drivers seat all the way forward, access the negative battery terminal, disconnect negative for 20 min and reconnect.
Old Apr 30, 2026 | 12:27 AM
GLE 450
What about a soft reset? Some key pair command?
Old Apr 30, 2026 | 05:15 AM
W205C43PFL's Avatar
It might also have to do with installing an update and once the installation is finished, operation resumes, although it should prompt you to park and lock the vehicle before starting... Normally.
Old Apr 30, 2026 | 09:15 AM
Lucky 777's Avatar
Top Answer: 1
2024 GLE 450 4matic
My 2020 GLE 350 did this a few times. Had to disconnect the negative terminal of the 12 volt battery under the drivers seat, I carried a 10mm wrench for just this purpose. With the 450 having the 48 volt system, I don't know if this is still applicable or not.
Old Apr 30, 2026 | 11:05 AM
BlueYonder's Avatar
2024 GLE 450, 2009 SLK 300
Hold down the Star key and the Phone Key at the same time on the center console. This will force a reboot.
Old Apr 30, 2026 | 11:10 AM
mikapen's Avatar
It's happened to me twice, and both times it was during an OTA update.
I wouldn't bother with disconnecting the battery unless it happens regularly.
Old Apr 30, 2026 | 12:37 PM
jkaetz's Avatar
2021 GLS580 | 2011 ML350 BlueTec | 2009 Pontiac G8 GXP
I've resolved most oddities by following the below sequence:
Shutdown, open the door (this puts most things to sleep), close door, wait 30 secondsish, then restart.
Old May 1, 2026 | 12:08 AM
vincheung's Avatar
S63, GLE580, BV250
I believe there’s a soft reset for the infotainment (press and hold power?) but driver’s screen I’m not aware of.
Old May 1, 2026 | 06:45 AM
W205C43PFL's Avatar
For those who have MBUX 2.0 or 3.0 does anyone know the soft reset procedure? Holding power button for example won't work anymore.
