GLE Class (W166) Produced 2015-2019
Radar Detector mount for GLE
Old Jan 20, 2016 | 01:44 AM
johnnyderm's Avatar
Soon: 2020 G63 Currently: 2016 GLE63 SUV + 97 F250HD, Before: 2013 G550, Range Rover Sport, 1984 CJ7
Post Radar Detector mount for GLE
Anyone have a radar mounted in their GLE, if so where? Thinking of mounting something to rearview. Would love any ideas that proven to work. Thanks!
Old Jan 20, 2016 | 06:41 AM
BACnMercedes's Avatar
19 E63s, ‘24SQ8, wanting another gas guzzling V8
Me too.
Old Jan 21, 2016 | 02:23 PM
troymir350's Avatar
2019 AMG GLE 63S
Have an ML but about the same. My Valentine is mounted to the left and up from the rear view mirror. Run the wire inside the headliner and plugs direct into the OBD port with option plug for the V1. Keeps rear detection possible and it's totally out of the way. Use the V1 windshield mount by the way.
Old Jan 21, 2016 | 02:52 PM
Off to find out what the OBD port is.............and if my passport can hook to it!
Old Jan 21, 2016 | 07:53 PM
troymir350's Avatar
2019 AMG GLE 63S
On Board Diagnostics port. Under dash on driver side. Dealer plugs computer in for codes. Or you can! Either way I'm not sure Passport has that plug. Valentine has a plug in option. Easiest "hardwire" there is.
Old Feb 6, 2023 | 05:45 AM
Goodwood's Avatar
2025 GLC 300, (formerly) 2018 SL550
OP was asking about a radar mount solution, not a solution for the power source. That said, the V1 SAVVY OBD power source does seem like an easy way to power up your radar detector w/o using a 12v receptacle, or needing any knowledge of wiring at the fuse box. Since the detector connects to the SAVVY with an RJ11, any detector with that connector could use this, not just V1. I still plan to have my trusted stereo shop hardwire mine to the fusebox to get all of the hardware completely out of the way, like I have always done.
Old Feb 8, 2023 | 11:50 AM
kajtek1's Avatar
1922 Ford Model T / no OBD
I just put it on the dashboard in the center and use the suction cups to hold it from sliding.
I move the detector between cars, so want it easy moveable. In my sedan, who uses it the most, I hid a cable, who goes from cigarette lighter socket to glove compartment, where I have 4-way splitter for detector, camera and other stuff. All the wires are hidden behind moldings, but that make them hard to move.
So when I need detector in GLE, I just use phone cables as power cable for Valentine One.
