GLE Class (W166) Produced 2015-2019
Sponsored By:
Sponsored By:
'12 ML 350 BTC ACS isssue ?
Old 12-22-2016, 11:44 AM
PurpleS500's Avatar
2012 ML 350 Bluetec W166
im having a issue on my 2012 ML350 Bluetec. Every time i turn left at speeds of 25 and above I get Malfunction with arrow up on the dash . Anyone with the active control system issued this ? I'll attach pictures of what I'm seeing and what is showed when scanned . Can it be the pump as described in this thread not allowing enough pressure .. supposedly the pump is on the engine bay in the front . I'm located in the New York City area if anyone can help me resolve this issue , from pump being bad not giving enough pressure or a shock but shocks seem fine and normal height and don't sag don't when not in use in a long time . Thank You
Old 12-22-2016, 12:22 PM
Plutoe's Avatar
Received 1,021 Likes on 949 Posts
1999 E300TD
You are thinking to much-----don't make any left turns or change the faulty sensor and get on with your life!!
Old 12-22-2016, 01:12 PM
PurpleS500's Avatar
only if if I knew which sensor and i was one always to make left turns not right lol
Old 12-22-2016, 01:31 PM
Plutoe's Avatar
1999 E300TD
Post your VIN!!
Old 12-22-2016, 03:50 PM
PurpleS500's Avatar
Post your VIN!!
Old 12-29-2016, 12:14 AM
PurpleS500's Avatar
Bump ✊
Quick Reply: '12 ML 350 BTC ACS isssue ?
