Tire Recommendations: Michelin Premier vs Defender
I actually ended up purchasing them at costco and they are on their way this week. What's the worst that happens you know? Dealt with the conti's this long, can't imagine defenders will be any worse. I really like the comfort/ride of the conti's during their first 10k miles, now they are garbage at 25k miles. I do like a little bite as I don't want it to feel like im driving on a cushion, but I also don't want to feel every crack in the road. Mercedes suspension does a pretty good job at ironing those out. Do you have a way of describing this bite that you felt? was it in a good/bad way or just an annoyance to you? If you hadn't had the ability to swap to the premiers (seem's like you got a special 30 day trial), do you think you'd be annoyed with keeping the defenders knowing the above and having used both?
edit: as far as the premiers being better because they are soft, it's not true in this case. The defenders are actually designed more so for snow/wet conditions than the premiers due to the treads. How the rubber changes with cold temperature is more indicative of the rubber composition and how well it will work in snow(you also want the tires to grip and hold snow, this is what gives you traction...completely against logic I know, had to check for myself lol)
I need to buy tires for my son's Escape before winter and I think the Defender tire will work perfect for him
