Baby seat position?
TIA
Good tip - since center position is not as "flat" as outboard seat section - yep - a mat will help in general fitting.
https://saferide4kids.com/blog/where...your-car-seat/
http://thecarseatlady.com/center-or-side/#
If your car doesn't have LATCH hooks for the middle seat, check the owners manual before you "borrow" from the outboard seating positions. Some allow for it, some don't. Also, heads up, LATCH is only recommended up to a certain weight limit (weight of the carseat + weight of kiddo). You have to check the owner's manual for both the car and the car seat to find out the weight limit. We switched to a new car seat this summer to keep our daughter rear facing. The new one is pretty heavy and as a result, we had to switch to using the seat belt instead of the LATCH anchors. I sure missed the LATCH system at first and I ended up emailing pictures back and forth with the company before I was happy with the install. It takes some getting used to, and there are definitely some tricks to. But I have my daughter's Clek Foonf installed rear facing in the center position using the seat belt right now of a 2018 GL350. In fact, I have the car for an extended test drive and I just installed it this evening. It was easier to install in the GLE, and I think I am getting a better installation overall, compared to my Honda Odyssey.
I'm sorry to disagree with another member, but if your kiddo is forward facing then you absolutely should use the top tether regardless of if you are using LATCH, or the seat belt. If your kiddo is rear facing, only certain car seats can/should be tethered (it's a short list of the ones in the USA that can be tethered). Here are a couple of links that talk about tethering:
https://csftl.org/why-tethering-is-so-important/
http://thecarseatlady.com/rearfacingtether/
I've been lurking on this site for a day or two, but when I saw this thread, I had to post. Car seat safety is something I am really big on and research a lot. However, everyone's situation is different and I'm not going to put anyone down for their choices. But I just wanted to share the information from respected resources that I have found when I was trying to figure out similar questions for our daughter. I hope this helps you figure things out.
Always do rear-facing until 2yrs old(or above set weight limit), im pretty sure that’s the law in the US.
