Theft Deterrent
I picked these up a week ago. At first, I was looking for regular "Security System" stickers. I stumbled across these, which I thought were a lot better. How many times have you heard a car alarm blaring and ignored it? Knowing the vehicle is being silently tracked via GPS is a much better deterrent. The adhesive is on the side with the "lettering". They go on the inside surface of the glass. I installed them on top of 40% window tint. With white lettering against a clear background, they're noticeable, without being too conspicuous. They measure 1.18" x 3.42" (30mm x 87mm). The price translates to $5.59 U.S. dollars (including shipping) for a pack of 5 high quality, vinyl stickers. Shipping from the UK to the U.S. was 7 days.
By the way, this is NOT a ruse. If you have Mercedes Me, you have GPS tracking via the "Locate Vehicle" feature.
https://www.shop4stickers.co.uk/merc...ker-1409-p.asp
That car could still be tracked using Mercedes me.
Thanks for posting this!
Deactivating and Activating SmartKey -
If you do not intend to use a SmartKey for an
extended period of time, you can deactivate the
KEYLESS-GO function of the SmartKey. The
SmartKey will then use very little power, thereby
conserving battery power. For the purposes of
activation/deactivation, the vehicle must not be
nearby.
1. To deactivate: press the "lock" button on the
SmartKey twice in rapid succession.
The battery check lamp of the SmartKey
flashes twice briefly and lights up once, KEYLESS-GO is deactivated.
2. To activate: press any button on the SmartKey.
