GLE Class (W166) Produced 2015-2019
2016 GLE 4matic 300d engine
Old Jul 6, 2018 | 11:01 PM
mcclane89's Avatar
300d
Hello
Looking at buying a '16 GLE 300d 4matic and doing various research on it. Had a question:
Was 2016 GLE 4matic 300d engine sold only in US? I ask because it seems that this model never hit the euroean market where diesel engines are popular and proven. Wonder why MB would develop a diesel engine only for US only to kill it again a year or so later.
Old Jul 7, 2018 | 08:23 AM
MercDriver125's Avatar
GL350
The 4 Cyl turbo diesel is, I think same as the sprinter van base Diesel engine. That engine was discontinued on the Sprinter, same time, so MB would only have to get one diesel EPA certified...thank you Volkswagen!” It is not sold in Canada and there are many iterations of diesels in Europe. I just sold my GL350 bluetec, primarily due to the emissions requirements, which here in the US are more rigorous than anywhere else in the world.
The emmissions requirememts have taken a perfectly good engine, and greatly complicated the reliability, especially with the required exhaust gas recirculating valve, which essentially re-routes exhaust, which is carbon rich, back into the engine. I replaced my GL with the gas GLE 350. The difference in torque (lower) is noticeable.
I also purchased a sprinter van for my business, and was able to buy a special extended warranty on the emmissions...which is a separate service contract. It would make sense to carefully review the MB extended warranty - which I highly recommend- to identify if it includes the diesel emmissions and DEF (diesel exhaust fluid) system.
I seriously considered the GLE 300D and would have purchased one, if MB was still producing the, for the states. For now, absent the Sprinter van, they are out of the diesel market, I ultimately opted to go with the gas version. I’d be very interested to hear the outcome. I hope this helps.
Old Jul 7, 2018 | 10:03 AM
mcclane89's Avatar
300d
Thanks MercDriver125. This is very insightful. Quick question/clarification: The 2016 GLE 300d is a 4-cylinder engine. Did this engine ever sell in Europe or was only designed for North America? If i may ask, what year was your diesel GL and why were you forced to replace/sell it?
Old Jul 9, 2018 | 07:58 AM
GL350
I’m not clear on the origins of the 4 cyl diesel, but suspect it has been in use elsewhere, since MB builds a lot of diesels outside the states. I really enjoyed my GL 350, and without the extended warranty would have had significant expenses. If you research the v6 diesels on the site, you will discover there are some known problems.
My GL blew the oil cooler and engine seals, under warranty. It’s at least a $4,000 service bill. Unreleated to diesel, the air Matic front suspension and compressor failed, also under warranty (this problem for GL usually evidences itself between 75 - 150k, gas or diesel) and I suspect rear suspension would be soon too...had about 90k on the odo. Previously i I had a 2008 R class diesel, the engine was perfect! All the other stuff, however cost me about 13k in service over 2 years. So maintanence is a factor.
I tradeded my GL almost at the end of the warranty with the expectation that it would continue to cost real money to service. I couldn’t find much on the 4 cyl diesel, pro or con, but had hoped it would prove to be a better long term engine. Ultimately, it’s the U.S. diesel emmissions that complicates what should be a solid design. While it is my preference to drive diesels, until MB puts one into to passenger car service again, new, and supports it, I’ll pass.
Since there is no (negative) evidence on the 4 cyl, it could turn out well. That engine was also used for a couple of years on the GLK and the E class sedan from I think 2014 - 2016. Best to you in your research. My gut feeling is that it’s a good engine, however the if the extended warranty won’t cover the DEF and emmissions, it’ll be expensive to repair. Depending on the in service date of the car, you might get a total of five years, but probably closer to fours years of MB warranty, included extended.
Utlimately, it’s the DEF (diesel exhaust fluid) system that can be problematic over extended use. However, I don’t have any practical experience with 150k plus mileage on diesels...which should be easily achievable based on the design.
Old Jul 10, 2018 | 09:15 AM
mcclane89's Avatar
300d
Thank you MercDriver125. This is very helpful!
Old Jul 10, 2018 | 09:40 PM
Strafzettel's Avatar
2023 EQS 580 SUV
Originally Posted by mcclane89
Hello
That engine is or was available in almost all Mercedes models in Europe, they call it 250d instead of 300d.
https://www.autocar.co.uk/car-review/mercedes-benz/gle
Old Sep 29, 2018 | 09:19 AM
schlava's Avatar
2014 GLK 250
We have this 300d 2.1 now and had our glk250 for four years. Great motor not one problem since we've had it. I think the old 3.0 motor had more problems posted. I think in all my searching i've only read about problems with the DEF heater and that was far and few between. My wife loves the diesel motor and we got lucky finding the 300d as they are far and few between it seems.
Old Sep 30, 2018 | 03:24 PM
jin8282's Avatar
2016 GLE300d 4MATIC
My 2016 GLE300d is running great with 43000 miles on it. I tow a 3500 pound travel trailer and camp at many national parks in the west. I also drive out to the off-road once in a while. The diesel engine has so much power that I forget about the trailer even when it climbs the hill. The combined gas mileage is good also, 22 miles per gallon with both 300d (4 adults) and trailer fully loaded. 300d is a true SUV for the outdoor activities. As it is reaching the factory warranty limit (50000 miles), I'm considering the purchase of an extended warranty for 75000 miles, just in case.
