Help about Engine light on!
I have 2 questions:
1. Is it possible any service items in the list may cause this issue?
2. If unfortunately it is just coincidence that the misaligned part of engine happens after the maintenance, is the quote of at least $10,000 reasonable?
Tell the Dealer service manager, you want to see a regional Mercedes rep to discuss this issue and call Mercedes and let them know.
It personally scares the hell out of me since I have a 2015 that just turned 60,000 .
Keep us posted. Good luck
How common an occurrence is this on the M276 engine?
It's unlikely that properly performed spark plug change would cause this problem. There is some information on the internet that talks about possible valve damage if spark plugs are not torqued correctly on a direct injection engine. The M276 is a direct injection engine.
It's not impossible that the spark plug change caused the problem, but seems unlikely to me.
Do you know if it is common to have this issue for a 2016 GLE350 with 60000 miles engine? My warranty expired recently. Do you think if it will be useful to contact MB directly? Thanks
Error Codes Read -- P0019 Crankshaft Position - Camshaft Position Correlation - Bank 2 Sensor B
Definition -- Code P0019 indicates that the crankshaft and camshaft Bank 2 Sensor 'B' position signals did not correspond with each other for a predetermined period of time.
I googled and found there could be many possible causes, and one of the simplest solution could be to replace a bad sensor. It could be some complicated reason. However, I think with just 5-minute examination, the dealer asked me to replace the whole system with $10k is too premature. I will seek a second opinion from another dealer tomorrow.
It could be that the sensor is the only problem. Do you have other codes besides P0019? Do you have any observations from driving the car? Vibration, smoke from the tailpipe, rough idle, hesitation while accelerating? Strange gear shifting?
See where the advise here and calling MB gets you. Good luck!
I would send a complaint to MB HQ describing the problem with the attached paperwork.
