GLE43 SUV - Replacement brake discs and pads
I have a 2018 GLE43 SUV. I've always thought the the brakes on the GLE43 SUV were poor. I found they fade very quickly when very warm and also I thought the braking wasn't aggressive enough.
The car is in for a service with Mercedes today and they mentioned in the near future I would need to replace all the pads and they would probably advise changing the discs too.
Has anyone changed out the Mercedes discs and pads for 3rd party discs and pads - e.g. Brembo, etc...
I would love to upgrade to a big brake kit but can't justify the cost of that at the moment.
Any replacement disc/pad suggestions/experiences to share?
do you track your 43? depending on miles, you should first get brake fluid changed... air, moisture in fluid can affect fade...
No - don't track the GLE43 but I would 'drive with passion' on some Irish country roads! Car has 45,000 miles on it.
According to Mercedes today I only have a month or 2 left on the current Mercedes discs and pads hence thinking of swapping out for more aggressive pads and alternative discs. EBC, Brembo, etc.. - just wondering if anyone else had done that and if this improved the standard Mercedes braking experience.
My wife has a GLA45 with 6 pot calipers and the brakes are amazing.... just wish I could have the same experience on the GLE43 but I wasn't planning on changing the calipers at this point.
Yes GLE43 is lacking significantly in braking as compared to ML63 and GLE63 (the "real AMGs). I do have '19 GLE43 and braking being its most obvious shortcoming (I've addressed power and acceleration "issues" immediately to my satisfaction especially considering amount spent).
The only way to significantly increase braking performance is to upgrade to 63's hardware (very pricey).
Changing just the brake pads to something "more sticky" is the possibility I did not look into since I do not think it will solve the issue. Sticky summer tire, like PS4, will help just as much as sticky pads. Also sticky aftermarket pads may also likely create significant brake dust (just like 63's OEM), which OEM 43 pads do not. I think the larger problem is the calipers and not just the pads. 63's calipers and other hardware is expensive.
![](https://mbworld.org/forums/images/ranks/veteran_air_force.png)
The advantage of ceramic pads is absence of brake dust. GLE43 OEM MB pads ALREADY produce almost no dust, at least on my '19 GLE43. I also have '15 ML63. The difference in braking between the two is night and day. I found GLE350/400 brakes from loaners I had unsatisfactory even compared to GLE43. OP (as I am) is clearly looking for much more stopping power than simply changing pad's material can provide. To accomplish this, nothing short of proper (bigger, much bigger) calipers with supporting hardware will do.
IMO the GLE 43 has no worse brakes than many other SUVs... its an AMG wanna be... nice accessories, upgraded suspension, emblems e.t.c but where it really counts, starting, going and stopping, it's lacking...
Big brakes and big stopping power requires bigger pockets.
