'Active body control malfunction' error - advice?
Side note-I did do a search and didn't find anything related to GLE's about this topic.
Mine was leaking hydraulic fluid from a split line under the front ACS hydraulic reservoir. It was dropping fluid on my garage floor and the reservoir was going to run dry. You don’t want the reservoir to go dry and destroy your pump. That is very expensive.
If it’s not leaking, then it’s probably a sensor. If one of the sensors is acting up you might be inconvenienced / annoyed, but I’m not sure it’s catastrophic.
When I had a valve block need to be replaced, there was no indication from the system. It was just clunking and shifting the car oddly. Again, not immediately catastrophic, but annoying.
Good luck.
