P2617 Crankshaft Position Signal - Replace Procedure
Does anyone have the procedure for replacing the crankshaft position sensor on the GLE350?
I found that there was access to the crank angle sensor from underneath once I removed the aero panels. So I was able to replace it without removing anything else.
The car starts perfectly now, but the CEL is still on and the ECU is still in limp mode. Will the ECU reset by itself, or do I need to purchase a scanner to erase the errors and reset the CEL? Also, if I need to purchase a scanner, which one is recommended?
Thanks again.
