GLE Class (W166) Produced 2015-2019
P0453 Where is the EVAP pressure sensor located?
Old Aug 7, 2022 | 09:59 AM
Gmwml350's Avatar
2013 ML 350
I have a 2016 GLE 350 with a hard DTC P0453. I have cleared it and it came right back. Apparently this DTC means the EVAP pressure sensor voltage is high or it is shorted to voltage according to my scan tool. In order to start diagnosis, I need to locate the sensor. Can someone please tell me where it is located? Can it be accessed without dropping the fuel tank? Thank you, Gil
Old Aug 7, 2022 | 08:37 PM
chassis's Avatar
2017 GLE350 4MATIC
WIS shows the location. I am not able to access WIS at the moment, apologies.
Old Aug 11, 2022 | 05:20 AM
amusa's Avatar
16 GLE400 4matic
Fuel tank pressure sensor can also cause the P0453.
Old Nov 5, 2022 | 12:04 AM
pardesi's Avatar
2012 E550
Edit
Old Nov 5, 2022 | 09:01 PM
chassis's Avatar
2017 GLE350 4MATIC
Originally Posted by pardesi
I found it, pulled half of the bumper out but how the hell does one take the unit out. Not enough room to get a socket in there.
May have to remove the metal bumper frame.
Where are you in the vehicle? Doesn't look familiar. Given the hex feature for removal, if you can't get a socket in there, more components need to come out, or the assembly into which the sensor is installed needs to come out from the other direction.
