GLE Class (W166) Produced 2015-2019
Stop/Start system
Old Aug 19, 2022 | 04:37 AM
Musictalks's Avatar
GLE350d
Stop/Start system
Hi all. I've had my pre-owned 350 for about 10 months now. The auto stop/start worked, but now it doesn't. Its used as my wifes daily drive, but the stop/start doesn't work. All I get is the slashed yellow 'A' symbol. I've tried the dash switch, to no avail. Any help would be welcomed.
Old Aug 19, 2022 | 05:52 AM
amusa's Avatar
16 GLE400 4matic
Did you try pushing the ECO button. If it lights green then it's active. Or you may have issue with the main vehicle battery.
Old Aug 19, 2022 | 06:53 AM
chassis's Avatar
2017 GLE350 4MATIC
Can be related to aux battery condition. Replace it. Lots of threads on this site on aux batteries.
Old Aug 19, 2022 | 07:09 AM
Musictalks's Avatar
GLE350d
I dont have an ECO button. Just a button that disables start/stop (an 'A' )
Old Aug 20, 2022 | 03:41 AM
Musictalks's Avatar
GLE350d
I don't have that button. I haven't had an Aux. Battery error either.
GLE350D 2016
GLE350D 2016
Old Aug 20, 2022 | 07:05 AM
chassis's Avatar
2017 GLE350 4MATIC
GLE350D 2016
GLE350D 2016
Absence of aux battery indicator does not mean the aux battery is in adequate working condition. If this was my vehicle I would replace the aux battery, and likely the main battery.
With a 2016, the batteries could be as be as old as 7 years. You are overdue to replace both batteries.
Old Aug 20, 2022 | 09:19 AM
gearFX's Avatar
2016 GLE350 4MATIC
Interesting, was the auto start/stop a mid-model year addition, or a diesel-only thing in 2016? Mine doesn't have that "A" button.
Old Aug 20, 2022 | 09:54 AM
ron104's Avatar
2019 s-class coupe 2025 GLS 580 SUV2017 S-class cabriolet
I have a 2018, GLE 350,2WD and I have neither A, ECO buttons or stop/start.
So can assume the stop/start systems is NOT installed in my vehicle!!!!
ANYONE! ANYONE!!!
Old Aug 20, 2022 | 11:49 AM
chassis's Avatar
2017 GLE350 4MATIC
ANYONE! ANYONE!!!
GLE 350 with gasoline 3.5L NA V6 never were fitted with start/stop, thankfully.
GLE400, GLE43 with gasoline 3.0L TT V6 had start/stop.
Old Aug 20, 2022 | 08:43 PM
ron104's Avatar
Chassis, Thank you for the information.
I can now sleep tonight knowing That I did not get ripped off!!!
See Ya
Ron
Old Aug 21, 2022 | 07:20 AM
Chefcct's Avatar
2016 GLE 350 4-Matic
The original poster is in Australia…
not America…I can only assume they have différents specs on the cars?????
Old Aug 21, 2022 | 08:07 AM
John Ha's Avatar
2016 GLE 300d 4-Matic
I dont have an ECO button. Just a button that disables start/stop (an 'A' )Thanks
That is your "ECO" button (or at least that's what they call it in the owner's manual). I have a 2016 300D and my stop/start button has the same label yours has. The green light in the button is on when the stop/start is supposed to be working. I agree with others that your aux battery is suspect.
There are also fuses F212 (7.5A) and F240 (30A) for the stop/start system in the engine compartment fuse panel that you could check.
Edit - for some reason the images I uploaded yesterday showing the fuse locations aren't showing properly and I can't get them to show properly. Hopefully you'll be able figure those out.
Old Aug 29, 2022 | 05:50 AM
amusa's Avatar
16 GLE400 4matic
My 2016 GLE400 non diesel have the "A" button (ECO). My GLE is a USA model.
Old Aug 31, 2022 | 11:42 PM
Musictalks's Avatar
GLE350d
(Also fuse 15, in the cockpit, passenger side of dash.)
Old Oct 18, 2022 | 03:11 AM
Dinismb's Avatar
2005 Mercedes C230 Kompressor, 2008 GL 320 CDI, 2008 ML320 CDI, 2016 GLE 300d AMG Night Package
My 2016 GLE 300d has this option. It was working fine since I bought it a month ago. Now it is working intermittently.
Old Oct 18, 2022 | 07:15 AM
chassis's Avatar
2017 GLE350 4MATIC
Replace aux and main batteries.
Old Nov 7, 2022 | 02:37 PM
hessank's Avatar
2016 GLE 350d Coupe
I have a 2016 GLE Coupe 350D.
If you turn it off every time it stops automatically, at some point it will no longer stop in Auto Mode (for ECO purposes)
It appears to have a 'learning' feature. Mine did that too and was reset after I changed the battery
Old Feb 18, 2024 | 01:14 AM
harperb's Avatar
EQE350 4MATIC
My US 2016 GLE300d's stop start does not work (recently purchased). It has a green "A" light on, but when turning it it off, nothing changes in the center console (e.g. no amber A with the strikethrough). Is it likely the Aux or regular battery? Or maybe the previous owner disabled it somehow?
Old Feb 18, 2024 | 07:54 AM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
Yes, typically it's the auxiliary battery.
Old Feb 18, 2024 | 01:20 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
Had the same issue when I bought my 2016 GLE 2 years ago.
At the time I could not get definite answer on the forum, so assumed the car doesn't have the option.
So year + after purchase, the original battery gave up and I replaced. it.
ECO stop engaged on 1st red light after.....
The aux battery on those cars is very small, so I assume it powers parking brake and gear shifter only in emergency.
Old Feb 19, 2024 | 05:00 AM
MB2timer's Avatar
Veteran: Army
Veteran: Navy
SL63
That autostart feature is very misleading. It lures you into the idea that you are saving fuel, and thus reducing emissions. It also lulls you into believing you are being more economical.
Scotty Kilmer hates autostart. Very hard on the starter, and reduces starter life significantly. Hard on the batteries as well. Also hard on turbo chargers.
I have the option for switching it off, and I always do.
I seem to remember a study performed on the question of shutting off the engine while stopped.
To the best of my recollection it was 1 or 2 minutes was the break even.
Old Feb 19, 2024 | 05:51 AM
BenzNinja's Avatar
Former Vendor
Get it coded to ON/OFF remember
Old Feb 19, 2024 | 12:51 PM
kajtek1's Avatar
It is not misleading, it is true.
When it might shorten the battery life by small %, the biggest battery killer is "smart charging".
Good luck with listening to Scotty with MB ownership.
Old Feb 20, 2024 | 08:23 PM
BlownV8's Avatar
From my understanding, the auto start feature does not use the starter. Instead, it uses direct injection to start the car through cylinder ignition.
Old Feb 20, 2024 | 08:35 PM
Chefcct's Avatar
I found a very good technical answer to your question on line…"
Automotive engineers don't use 'traditional' starter motors in these situations," he explained. "The starter used for start-stop systems combines several technologies."
What follows is his explanation of those technologies, lightly edited by Green Car Reports for clarity and style.
(1) The gear ratio from the starter-drive pinion to the flywheel ring gear is optimized to make the starter's motor turn more slowly. This can be done without materially changing the design of the transmission or flywheel at all on existing
Crucially, this reduces starter-motor speed (in RPM), since 90 percent of starter-motor brush wear occurs not during cranking, but during the coast-down after the start has finished. If a higher-torque motor can spin more slowly, its coast-down time is shorter, increasing its longevity.
(2) The composition of the carbon and copper brushes on a start-stop motor differs from its traditional counterparts to increase longevity without accelerating the wear on the commutator.
(3) Rather than rely on oil-impregnated bushings for the rotating assemblies, start-stop starters mostly use needle bearings.
(4) The solenoid on start-stop starters decouples the mechanical action of engaging the drive pinion into the flywheel from the electrical action of stopping and starting the motor.
This allows for a dedicated design to turn power on and off to the motor, optimizing contact design and wear, against contacts that have to be integrated as part of a spring-loaded plunger.
This also reduces the electrical load requires to turn the engine, so that there is enough current available for accessories/lighting to operate during the start event.
(5) Finally, start-stop motors are integrated with other technologies that identify when each cylinder of the engine will reach top-dead center.
That lets the fuel injectors pulse and fire during the middle of a complete rotation of the crank, against having to wait for a complete revolution that lets the first cylinder reach that position to start the fuel-spark timing sequence.
And there you have it: the full technical explanation of why you don't need to worry about starter motors wearing out prematurely due to start-stop systems.
