GLE Class (W166) Produced 2015-2019
Ambient Temp Reset
Old Dec 9, 2022 | 08:32 AM
patrickmartin62's Avatar
2017 GLE 350
Ambient Temp Reset
Hello,
After a minor collision I had the body shop make the repair and replace the ambient temp sensor in the front right bumper. It is still reading -40C. Does this sensor need to be reset/calibrated? If so, how?
Thank you!
Old Dec 10, 2022 | 12:54 AM
chassis's Avatar
2017 GLE350 4MATIC
The body shop needs to fix this. Anything can be done with XENTRY if you or the body shop has it. The dealer has it, and good indys have XENTRY. This is the body shop's responsibility.
Old Dec 10, 2022 | 09:11 AM
2017 GLE 350
Thank you. Agreed. Just doing some research on my own. Just to clarify, after new sensor is installed it has to be set through the xentry system?
Old Dec 10, 2022 | 09:53 AM
chassis's Avatar
2017 GLE350 4MATIC
Don't think so. Either it doesn't need to be reset or calibrated (the body shop didn't install it correctly) or it needs to be done with XENTRY. If you can verify whether the sensor was installed correctly (harness connector fully seated), it will point to the XENTRY scenario. You should call the body shop and tell them the situation and for them to prepare to either take your car to the MB dealer or for them to fire up their XENTRY system. Smaller shops (e.g. body shops, glass shops) take cars to main dealers all the time, they should not give you any push back.
Old Dec 10, 2022 | 01:15 PM
2017 GLE 350
That's great information. Thanks very much!
