GLE Class (W166) Produced 2015-2019
2016 GLE 350 new battery CCA low
Old Jan 27, 2024 | 11:39 PM
greypoint's Avatar
GLE 350
I just recently replaced original battery at dealership. After connecting to CTEK charged to full, using battery tester I found out it only showed 663 CCA fully charged using type AGM flat plate. That doesn't sound right. The full capacity should be 900 CCA? Does the new battery have issues?
Old Jan 30, 2024 | 11:21 AM
kajtek1's Avatar
1922 Ford Model T / no OBD
What meter did you use?
I bought new H8 battery at Costco and my Solar tester show 1600 CA on 1000 CA rated battery.
CCA applies to temperatures about 0F.
Old Jan 31, 2024 | 07:17 AM
John Ha's Avatar
2016 GLE 300d 4-Matic
I'm sure you're aware that you have to do battery tests connecting directly to the battery rather than to the jumper posts in the engine bay. That aside, I'd take it back to the dealer that installed it and ask them about it.
Old Jan 31, 2024 | 11:05 AM
whitewagon's Avatar
Aston Martin Vantage, GLE 43 AMG, Volvo XC60, BMW X1 35i, Ram 1500, BMW Z4 35i
Also check the date code on the battery
