Transmission Fluid change GLE350
Is there a "workaround" that I am missing because it did not seem worth the labor to gain access (the bell housing was not easily reachable with a drill bit) and risk of damage to drain the additional 3.75 quarts of ATF.
Am I wrong to think that simply changing the 5.25 quarts at more frequent intervals should protect the gears and valves?
Finally, though my dealer says they would drain the TC, I find it hard to believe that they taking the time to drill out bell housings to access TC drain plugs on these GLE's.
I've been doing pan service only for decades. Older 5G transmissions did not have plug on converter, when per my observation, the most of the dirt stays at the bottom of the pan.
So wiping the pan clean would be crucial service to me.
No workaround.
You are not wrong in thinking that smaller fluid volume changes done more frequently will approximate larger fluid volume changes over a longer change interval. Even when the converter is drained, cooler lines and the cooler itself are not drained.
I plan to change the ATF at 30-35k intervals going forward. The process is pretty straight forward and requires replacing the gasket, green overflow plug, transmission filter, 6 bolts, crush washer, and 5.25 quarts of fluid. Other than Pentosin 134FE, I used all genuine MB parts from my local dealer since I did not want any fit issues. Both the Pentosin and the adapter for filling the transmission came from FCP Euro.
If anyone has drained the TC on a 2015-2019 GLE, I would love to see some pictures of the bell housing access hole after drilling and know how you got a drill bit into that space (what did you need to remove and how long did it take).
Thank you again for sharing so much wisdom and experience on this forum.
On 1 transmission the bottom plug was over torqued and I was on the edge of stripping the head. In this case I just removed the pan full of ATF, what created a bit bigger mess, but still having big catch pan, pretty doable.
