GLE Class (W166) Produced 2015-2019
New Compressor Install
Old Nov 3, 2024 | 10:14 PM
Rivers's Avatar
Hello i recently had my ac stop blowing cold air. I replaced the expansion valve and recharged system which worked for 1 day then back to hot air. I purchased some better ac gauges which was showing very low pressure on the high side (50psi) so I then proceeded to install a new compressor. The issue now is that the AC button flashes 3 times and the compressor never kicks on. Am I missing something?
Old Nov 7, 2024 | 12:30 PM
AlanD26's Avatar
GLE 350
Im having my compressor replaced in the shop on Monday (November 11th) . I'll mention this to them and see if they can shed any light on it.
Old Nov 7, 2024 | 12:42 PM
Rivers's Avatar
thanks that would be greatly appreciated, I started by replacing the expansion valve then pressure switch before the new compressor and now i hit a wall.
Old Nov 7, 2024 | 01:46 PM
trigital's Avatar
W213 All-terrain
You can try to delete fault codes from KLA module, although any Fault code would have been very important before any purchase.
A normal procedure besides cleaning somehow the tubes and radiators and to change the drier filter is to make the "Brake-in " procedure with Xentry.
Old Nov 13, 2024 | 04:43 AM
amusa's Avatar
16 GLE400 4matic
I have seen bad compressor get sold off the shelves. Dealer only sell reman ones for a hefty price.
Old Nov 13, 2024 | 11:44 AM
AlanD26's Avatar
GLE 350
I’m so sorry, with everything going on, I totally forgot to ask the mechanic about this, apologies.
