GLE Class (W166) Produced 2015-2019
AC Pressure Sensor Wiring
Old Nov 14, 2024 | 09:07 PM
Savin' a buck's Avatar
2016 Mercedes GLE350
Can anyone help? I learned a 3 pin AC pressure sensor wire harness has a 5 volt reference wire, a ground wire and a signal wire. I disconnected the harness to check the voltage at the harness (not sensor) and I have two wires with 5 volts, my 5 volt reference wire and my signal wire. Can't find a schematic but is this right? I'm troubleshooting some issues with high pressure on the low side and ran into this when testing my AC sensor then harness.
Any advice would be much appreciated!
Grandma in the Garage
2016 Mercedes GLE 350 Base V6
