GLE Class (W166) Produced 2015-2019
Spark Plug Cross Thread Question
Old Aug 4, 2025 | 04:51 PM
haf39's Avatar
2018 GLE350 4Matic
I have just finished installing 6 new plugs and coils in my 2018 GLE350. No major problems came up during the installation, with the driver side plugs being the most time consuming to get in.
Drove the car 100 plus miles since with no issues, feels smooth, and no codes stored.
My question is this, especially for the #6 plug as it was almost impossible to see into, how easy is it to cross thread a spark plug? All plugs were started by hand, and then switched to a ratchet there after. While I did encounter minor resistance, all six plugs went in with relative ease and all torqued down to spec.
I guess I am concerned given the lack of visual confirmation for the driver side plugs. Would there be ignition symptoms if a plug was cross threaded? Or can a cross threaded plug last for the entire service interval?
Old Aug 4, 2025 | 10:25 PM
chassis's Avatar
2017 GLE350 4MATIC
Did you achieve the torque spec on #6 plug?
Old Aug 4, 2025 | 11:11 PM
Mikes62's Avatar
You were probably feeling the carbon buildup in the threads. If you started the plugs by hand, was able to turn them a couple of turns by hand, then they tightened up with a ratchet, you’re all good.
Im sure you would have known if you cross threaded one of them. It takes quite a bit of torque with the ratchet if it’s cross threaded.
Old Aug 4, 2025 | 11:44 PM
haf39's Avatar
2018 GLE350 4Matic
Yes, all plugs were torqued to 23 Nm.
Old Aug 4, 2025 | 11:59 PM
MacVidMB-V8's Avatar
W209, W124
Cross threaded one in a Big Block Chevy once. Ran fine then one day I got on it and the spark plug shot out like a bullet. Car made a hell of a racket. Got a new plug and all was well. Cast iron heads.
Old Aug 5, 2025 | 12:29 AM
haf39's Avatar
2018 GLE350 4Matic
Sounds fun. So you didn’t notice the plug had been cross threaded when installing?
Old Aug 5, 2025 | 02:52 PM
W209, W124
I was 16 or 17, first time changing plugs. The car was crusty with rust and oil crud. The plugs had anti-foulers on them so went in weird anyway. I didn’t notice but paid much more attention from then on.
