Brake Squealing Issue
Does anyone has similar experience before? what is the potential issue?
Mercedes Brake Pad Set
TEX-2519201
TEX-2521502
Sometimes new rotors have a coating that needs to fully wear off. The squeal at light pressure is classic for vibration between pad and caliper. Remove, clean everything, lubricate all contact points (not the friction surface) with proper brake grease, and bed the pads in again with a few moderate stops. If it persists, the pad material itself might just be noisy.
I'm not sure the noise come from with corner yet, hard to tell.
I used the hardware shown in https://www.fcpeuro.com/public/asset...-2521502-2.JPG, removed the old one and replace with new one. I didn't apply lubricant to the edge or back of braking pad, only apply lubricant to the rear sliding pin. I have already done with several moderate stops, I think bedding-in should be fine
not sure if those are "anti-squeal shims" you are referring to.
