GLE43 Coupe (C292) 2016 - Present (Includes GLE450 Coupe)
ECO Start/Stop Defeat Options
Old Nov 13, 2018 | 04:48 PM
UnlikeAnyOther's Avatar
2017 GLE43 AMG Coupe, 2015 GL350 BT, 2015 & 2014 E250, 2014 E350 Cabrio, 2011 E350 BT
Just some info for my fellow GLE 43 owners on ECO Start/Stop defeat possibilities.
I installed and have been using for a while now Midcity Engineering's "ECO Off" product with great success in my GLE 43. In order for the product to function correctly for my requirements, Midcity needed to make an update to the product which they did for no charge and were super easy to work with.
Long story:
Basically, the "ECO Off" product in my 2014 E250 turns off the ECO button upon startup (about 5-10 seconds after start up) and the vehicle will never try to turn it back on during that key cycle. If I want to re-enable ECO Start/Stop, I can just press the ECO button and the system works as normal.
However, in the GLE 43 (and with most AMG products) if I change the vehicle mode (Slippery, Comfort, Sport, Sport +, Individual) to another setting then back to Slippery/Comfort/Individual it will turn back on ECO. Reason is that in Sport and Sport +, ECO is automatically disabled. For me, I not only wanted ECO off at start up, but also when switching modes, as I go from Sport + to Comfort at times and I wanted ECO off all the time. The fix was to reprogram the "ECO Off" unit to always switch the ECO function off if it ever turns on (green LED). And it works great! Now, if I ever want ECO to function, I still have a mechanical switch I can use to kill power to their circuit board and thus enables all ECO functions (great if I need to bring in for service too). After several months, works great and no side effects with the vehicle at all.
Below is the link and if you need the modification I described, just give them a call before you order.
They are very friendly and easy to work with.
Midcity ECO Off Link
BTW: I am a customer of Midcity and paid for my products. I was not paid to post this, rather appreciated their support and thought that others may have a similar need.
And yes, feel free to save money and just push the ECO button every time - to each to their own right.
Old Nov 14, 2018 | 01:06 AM
fabbrisd1's Avatar
A gaggle of MB's
Thanks for the post - however with regards to ECO (on/off) - the "better" solution is the OBD module/reprogram from Vladimir in Belarus...
The OBD module plugs in for reprogramming - when reprogrammed - the OBD module comes back out..... now the re-program is simple - if ECO is OFF when the car is turned off - when started back up - ECO stays off. If ECO is ON when MB is turned off - then ECO is OFF when MB is started back up... so control is your choice.
Message Vladimir your VIN# and he will message you back with other features he might have to add to your module.. some neat stuff..
https://www.ebay.com/itm/MERCEDES-ca...-n9S:rk:7:pf:0
Old Nov 14, 2018 | 07:28 PM
Hello fabbrisd1,
Thank you for posting an additional option. That's what makes the forums so great.
All the best.
Old Nov 21, 2018 | 05:12 AM
legendary's Avatar
Veteran: Marine Corps
2008 CL550, 2018 E400 Coupe, 2019 AMG GLE43 Coupe, 1968 C10 Restomod
Great info! Thx all!
