GLE43 Coupe (C292) 2016 - Present (Includes GLE450 Coupe)
Question on diameter of Mercedes Star
Old Mar 9, 2020 | 08:46 PM
Isawelvis's Avatar
Veteran: Air Force
, 2023 BMW X4, 1991 190E
I installed an after market (China) Diamond grille on my 2015 ML. The grille is a littler taller than the one that came on my car even though its supposed to fit ML 2015-16, I was able to make it work but then I found out the Mercedes star on the grille that came on my car is too small. the Diamond grille has a larger diameter star.
I need someone to measure the opening for the Mercedes star. What is the diameter? Since this is a after market grille I need to make sure the OEM star will fit it
Also , do all GLE43 have the solid Mercedes star insert. Since my car does not have distronic cruise and stop feature, mine is the 3D type.
Thanks in advance.
Old Mar 10, 2020 | 10:42 PM
Isawelvis's Avatar
Veteran: Air Force
I think I have found what I needed. I went to Mercedes Parts cite and order whatever comes on the 2016 GLE450. It was a lot cheaper than I thought so it won't be much of a loss if it doesn't work.
