Wheel Hub Replacement
I am working on replacing a wheel hub on a 2019 GLE43 Coupe, following instructions as attached.
On step 4 it says to use extraction/insertion tool 210589034300.
Is this just supposed to push the front axle shaft back out of the steering knuckle/wheel hub?
Could I just use a universal wheel hub puller to push the axle shaft?
I need to get to these bolts and the boot is blocking them.
Bolts blocked by boot
Thanks in advance!
