2018 GLE63 S Brake Pad Recommendation?
Hey Guys,
Got 14k miles and need new rear brake pads. OEM installed looks like $500. Does anyone recommend aftermarket brakes as opposed to OEM? I'd love to minimize the brake dust if I could but I don't want to compromise quality. Thanks in advance! |
Originally Posted by scamara01
(Post 7738913)
Hey Guys,
Wow, 14K miles and need new pads. Is that what I'm to expect with my 2019 GLE63s AMG Coupe with 2,500 miles on it? My car took a 1,000 mile trip from Arizona to California and I noticed a lot of brake dust as well. Given the 4-matic all wheel drive uses brakes to correct I thought this may be a constant burden on the brakes. I disabled the active lane correction feature and have notice much less brake dust. Hopefully this will save on brakes as well. I also like to butt-dyno the car a lot (aggressive acceleration) I disable the traction control to only inclimate weather. Much better hole shots.
Originally Posted by wwatsonjr
(Post 7866234)
Wow, 14K miles and need new pads. Is that what I'm to expect with my 2019 GLE63s AMG Coupe with 2,500 miles on it? .
I replaced all four pads and rotors from fcpeuro. Drive the exact same and there is no difference in braking.
Da Man!
Originally Posted by E55 KEV
(Post 7866580)
see this thread only 5 posts down from top thread - https://mbworld.org/forums/gle63-gle...s-already.html
Thanks for this post E55 KEV. The youtube video post within (
Thanks, https://cimg1.ibsrv.net/gimg/www.mbw...9e5728e906.jpg The trail blazer |
Replaced my rear pads today,,, 27400 kms (16,600 miles) and they were 95%.
I opted for these from Rock Auto Bendix CFC1639...cost me about $45 CDN all in These did not come with the wear sensor which btw is only located on the passenger side. Luckily my pads were worn almost into the indicator but I could still re-use it..there is a small hole in the top of the pad that the indicator fits into. All went well. I had never done and it took about 1.5 hours...I could do now in an hour or less.. Initiating brake service with steering wheel/dash menu is simple..I used a clamp to force the piston back into the caliper..also simple I also gave the calipers a good cleaning. We'll see how these pad perform -dust -noise -performance -durability Dealer wanted $600 CDN to replace rears only and $800 for supply only f/r pads. Rotors are in good shape and when I need front pads I'll do a complete f/r rotor/pad from fcpeuro https://cimg8.ibsrv.net/gimg/www.mbw...27d2abca5.jpeg |
Nice work. How did you lift the vehicle? Interested in what adapter, if any, was used to fit into the jacking point.
Floor jack...jack stands
Originally Posted by chassis
(Post 7876379)
I just did one corner at a time and jacked directly under the suspension component so the wheel raised immediately..then I put a stand under for safety...so far no squeaks..squeals...no brake noise AT ALL
Powerstop Z16
Originally Posted by byroll01
(Post 7887834)
I used these for my ML63 and am about to install front and rear on my GLE. Great price, stopping power and very little dust. Calipers stay bright red for many washes.
Front: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 Rear: https://www.amazon.com/dp/B07H3FLNZY..._WSzTDb1VWN7Y3 |
(Post 7887834)
(Post 7887834)
Front: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 Rear: https://www.amazon.com/dp/B07H3FLNZY..._WSzTDb1VWN7Y3 Front $31.79 - https://www.rockauto.com/en/moreinfo...53930&jsn=3106 Rear $27.79 - https://www.rockauto.com/en/moreinfo...53930&jsn=3105 Rock Auto have pads listed under 4 categories - 1) Daily Driver, 2) Premium, 3) Economy and 4) Performance. The above Power Stop Z16 line is considered Economy. |
I think GLE/ML 63s are anything, but "economy" and I think need pads to stop it (dust or not, the first job for me is stopping). I, like the next guy, hate to over pay (for the identical item), but usually if "generic" replacement is to good (cheap/inexpensive) to be true, it usually is. I'm OK putting Textar (identical to branded MB except for absence of the logo) at the rear for 2/3 of the price (as compared to the identical item with the logo), but this staff... I do not know. Obviously one never knows how they "perform" until one tries them on, but since my life depends on it I do not want to chance it.
(Post 7888165)
Cheaper at Rock Auto:
Originally Posted by Gman123
(Post 8646345)
Bro, can you also send links for brake sensor? I appreciate that.
I was wondering the same (brake pad recommendation)
Brake pads are typically one of my first mods because OEM performance pads dust like crazy in anything I've owned. I typically get ceramic pads for the street because sports cars have a ton of braking power. Even on ceramic pads, they can lock up the wheels at fairly high speeds. However, the GLE is pretty heavy. This time around, for my street car, I went with the Carbotech 1521. It has pretty darn good bite for a street pad and while it does make SOME dust, it's pretty low. Ceramic on the other hand makes virtually zero dust. I use these on the Viper because, for some reason, it has pretty undersized brakes for what it is and a lot of grip (aero + tires). They also don't make it for the GLE63, but I'm willing to bet if I called Carbotech, they'd make me a set. It's not that big of a deal. I'd be curious to hear if ceramics have enough braking power or if I need to step up to 1521. |
New pads from Brembo for W166 AMG:
Ceramic Front: P50127N – Brembo Store USA Ceramic Rear: P50101N – Brembo Store USA OE Front: P50127 – Brembo Store USA OE Rear: P50101 – Brembo Store USA |
About to order parts for front and rear pad replacemenet. I've done rears before and it has1 brake wear sensor on rear passenger side. Anyone know how many wear sensors on front. Thanks.
Front Sensor: https://cimg9.ibsrv.net/gimg/www.mbw...6ea135b74a.jpg Rear Sensor https://cimg4.ibsrv.net/gimg/www.mbw...a84d3ed30d.jpg |
Only one sensor on the front passenger side.
(Post 8708887)
Originally Posted by grantwoodtx
(Post 8708979)
(Post 8682522)
