Brake Squeal on GLE63S
My braking style is to brake early with more pressure, then feather the brakes as I near the stop, using light pressure to roll to a soft stop. Under this light pressure, the brakes are squealing. And it’s not just one wheel. I can have 3 wheels squealing at the same time.
I have had it back to the MB dealership and on three different occasions they have replaced both front and rear pads. And the brake squeal continues! 😫🤬
Dealership appears to be running out of answers. But I refuse to live with squealing brakes on a $130K vehicle that is a year old.
Suggestions?
I haven’t paid a dime, so that’s a good thing. I’m scheduled to take it back in three weeks from now and they will “document” the issue and “open a case,” whatever that means. This will be the 4th time I’ve had them address this issue in the past year. What else could they need to document?
Wish me luck!
https://www.youtube.com/watch?v=fUNHb9O52WQ
Have you been bedding in your brakes after the pads and/or rotors are replaced? If not, you should try.
This is the second Lemon that I recently bought from Brooklyn Mercedes. I lost $30k with my return on that crappy vehicle.
did you mean to post this
I am always surprised when people buy performance products, and then complain that the performance products (brakes in this case) do exactly as designed.
High performance brakes are different than grocery-getter brakes. They will squeak when stopping if you don't treat them like they deserve, which is proper bedding in as @GlennC posted.
The operator has a role to play in the operation of the vehicle. "Officer I didn't know my car would go faster than the speed limit. I'll sue M-B."
See if you can find some grocery-getter pads, but if you do, don't use the other capabilities of your car. It will be unsafe.
If you try suing the Dealer of M-B for not changing to unsafe and non-approved parts, I hope M-B prevails. I don't want frivolous lawsuits adding to the cost of my next car.
Or you could just treat your equipment correctly. Now that you know how to take care of your car, good luck.
