Finally! Adjustable Camber Arms for our cars
Old Aug 5, 2020 | 09:08 AM
hadam3's Avatar
Top Answer: 1
996 Turbo, E86 Z4M, GLE 63 AMGs
So after lowering my car with the Amazon Module, my rear end was constantly searching for traction. It became super unstable - especially when only one wheel hits a bump, and the entire back end lags behind the front.
The only solution prior to these adjustable arms,
1. Adjust the stock setup - but adjustment is very limited
2. is a company (will not specifically call them out, as i do not have personal experience with them) that posts on this forum group frequently. I almost went with their kit, till i read a negative review from a fellow member here.
https://mbworld.org/forums/gle63-gle...day-pic-3.html
I know that experiences can vary depending on installation as well. As much as i wanted to give this product the benefit of doubt - a quick search on other forums here strongly supported the above mentioned post.
Hence i decided to start searching around more, and actually came across a company called "The Camber King" - Formally known as "F-1 Fabrication". His price was super affordable for what you get, compared to the camber kit mentioned above, hence reached out, and had a set of REAR camber arms over-nighted.
The install was a BREEZE, and my ride has TOTALLY transformed. The shop was able to get my rear camber aligned to OEM Specs, and the car now feels more planted with greater amounts of traction. The darting previously mentioned in the rear end, has now moved over to the front... which is something i have requested the Camber King to produce for our ride. He estimates production end of this month, and i am eagerly waiting to get his front camber arms on my car.
So far, my experience has been fantastic, but of course on time will tell on durability - will report back.
Link to the Camber King:
https://f1-fabrication.myshopify.com/
Old Feb 21, 2022 | 10:59 AM
charles.soori's Avatar
2014 ml63 and 2014 ml350 bluetec
Hi,
I just got a gle63 and lowerd the vehicle but man the rear looses traction. I had a ml63 lowerd and never did that.
Anyways I'm trying to get a rear camber adjustment but i dont see any listing for gle on the website you posted. Which one did you buy and how does it handle in this 2 years you had it.
Old Feb 21, 2022 | 08:27 PM
slk55er's Avatar
2024 GLB35 AMG, 2020 S560 Coupe
Rear toe-in can also be a source of that behavior. When I got my neon green '74 Fiat X1/9 (one of the 1st in the country), the shop misread the toe-in specs and set it to 0.5 inches rather than 0.05 inches. When hitting a puddle or patch of ice, the car was really squirrelly and the rear tires were shot after 2000 miles. The shop corrected the toe-in, replaced the tires and all was well thereafter. (Kept the X1/9 for 35 years and sold it for more than I purchased it -- $4300.)
Old Feb 26, 2024 | 03:42 PM
ii__tesh__ii's Avatar
GLE 350
did you purchase the ML W166 kit? Any word on the front end kit?
Old Feb 27, 2024 | 09:30 AM
suby01's Avatar
2024 AMG GLE 53
Youre literally replying to a post exactly 2 years later. Not sure youre getting a response.
Old Feb 27, 2024 | 09:52 PM
K-Mac's Avatar
SPONSOR
Mercedes-Benz CLK 550
We manufacture a Total range when it comes to adjustable Upper Camber arms for all SUV’s from W153, W164/X, W251, W166/X, C292 and current models W167, V167, C293 !
SUV being heavy vehicles unlike most other brands manufactured from steel not soft extruded aluminum and with extra H/Duty maintenance free bushings.
W166/X Rear Upper adjustable Camber Arms #504126N $695
Also includes extra “Toe” to compensate for the addition of rear Camber adjustment.
For the Front - we manufacture upper inner Camber and Caster replacement bushes having the advantage / security of retaining the original high strength forged alloy OEM arms #504016-2K $480.
NOTE: Because of need to remove both front struts to install do recommend instead:
#504016N $695
This kit replacing the 4 lower arm (highest wearing) bushings at same time - and the two rear are subject to premature failure and OEM are expensive to replace.
This kit also requires no special tools or need to remove arms from vehicle.
Adjustment also easier / more precise - direct on alignment rack single wrench and UNDER LOAD.
See Website - All the features / Listings.
AUDI to VOLVO - K-MAC Experience Of Resolving OEM Suspension Shortcomings Since 1964 !
