Mud Flaps Installed and Wheel Hubs Painted
Also I painted the wheel hubs with caliper paint 'cause Mercedes only paints these with a light coating of what seems to be primer which quickly deteriorates. This allows the hubs to rust and look really ugly. After only 300 miles, the hubs had some rust which I treated with rust discover, photo below.
Jacking the car and removing the wheels was a real challenge and I'll make a separate post on that ordeal.
Let us know how they stay put with 6" of slush caked to them. Good luck!
After positioning the flaps with duct tape, I marked the flaps for trimming and for where I thought all holes in the flaps should be. Then I drilled all holes in the mud flaps. I then positioned the flaps again and drilled the upper most hole through the mud flap and into the fender flare. I then installed that push-in rivet and completed drilling the other 2 holes in the edge of the flaps into the fender flares. After installing those two push-in rivets, I then drilled holes through the holes in the flaps into the wheel well liner. Of course, I was reluctant to drill into the fender wheel well flares, but these could be filled and painted and be pretty invisible if things don't work out.
