Ignition switched 12V supply for radar detector
Old Jul 13, 2022 | 05:27 AM
kiwiape's Avatar
GLE63S
I'm looking for an ignition switched 12V +/- source for my radar detector, can someone tell me where I can connect to please?
Old Jul 13, 2022 | 07:02 AM
Frenetic's Avatar
2023 S500
Best thing would be to hardwire it to a ignition controlled fuse position, but I know that’s a hassle. I plugged my dash cam into rear passenger USB-C port, tucking it in the center console carpet and under the dash. It’s ignition controlled. I think all of the USB-C ports are. They make cigarette lighter to USB-C power adapters as well.
Old Jul 13, 2022 | 12:12 PM
mikapen's Avatar
Be careful with that.
There have been reports on Detector Forums of people using a heated mirror circuit and overloaded the circuit when the heat comes on. Not reported on Mercedes as far as I have seen, but your BMW is one reported.
Old Jul 15, 2022 | 12:56 PM
slk55er's Avatar
2024 GLB35 AMG, 2020 S560 Coupe
I used the cigarette lighter in the center console for My Valentine V1. I ran the power cord across the passenger foot well and inside the windshield molding to hide the main wire. A separate wire is run to the remote display mounted on the steering column. A disadvantage is that the cover for the compartment in the front of the center console will not close but otherwise this is an excellent solution.
Old Jul 15, 2022 | 06:02 PM
jaxslk's Avatar
2025 GLE 450, 2022 AMG GLE 53
Exactly what I did though I took it under the driver side, away from the airbag of course. I use the cup holders too often to worry about ever closing it.
