Adjusting Camber Lowered 2019 GLE63S Coupe- Possible?
Old Feb 3, 2023 | 03:28 PM
cityvibe's Avatar
2012 458 Italia, 2012 E63, 2015 M6 Convertible
I recently purchased a 2019 GLE63S Coupe and lowered it 32mm using one of the $550 modules another forum member recommended. While I am very happy with the ride height and overall ride, the lowering has placed the car in a slightly negative cambered (-2.63 front) and (-2.55 rear) position. I have taken it to two pretty competent alignment shops to try to get the negative camber taken out as the car gets "jolted" over bumps and I'm a little concerned about tire wear as the 22" Michelins aren't cheap these days and I drive a lot of freeway miles. They both said there is no adjustment for the camber, but when I had the car at stock ride height, the dealer had aligned it and offered to remove some of the factory negative camber to make the car drive smoother as this particular model is notorious for driving a bit rough like a truck. For obvious reasons (warranty) I don't want to take the lowered car in for alignment to the dealer. Does anyone know if it is actually possible to adjust the camber once the car has been lowered, and if so, how?
Thank you in advance!!
