Needed advice for wheel upgrade with tire size
Old Sep 28, 2023 | 05:22 PM
ultradmp's Avatar
AMG GLE 53
HI all,
I want to change my wheel set to 23" or 24" (Vossen)
but then I just wanna make sure which tire size should I pick.
Front 275/45 ZR21 110Y (21x10 ET51 5x112)
Rear 315/40 ZR21 115Y (21x11 ET47 5x112)
Front 285/40 ZR22 110Y (22x10 ET56 5x112)
Rear 325/35 ZR22 114Y (22x11.5 ET53 5x112)
These are factory wheel & tire size chart.
If I go 23"
Front 285 / 35 ZR23 (23x10)
Rear 325 / 30 ZR23 (23x11.5)
If I go 24"
Front 285 / 30 ZR24 (24x10)
Rear 325 / 25 ZR24 (24x11.5)
If it is correct number, please let me know.
Old Sep 29, 2023 | 10:47 AM
suby01's Avatar
2024 AMG GLE 53
Pretty cool options with your sizes. Please post pics once you have your setup installed!!
https://tiresize.com/calculator/
You can check there to get the best idea of tire/wheel option fitments. But from what youre posting it looks like the tire sized for the wheels will fit. You just need to make sure it will clear the car itself and Vossen will help you with the custom offsets for that.
Old Oct 1, 2023 | 04:14 PM
slk55er's Avatar
2024 GLB35 AMG, 2020 S560 Coupe
Special Lub Bolts
Originally Posted by ultradmp
HI all,
If I go 23"
If I go 24"
Vossen probably knows, but don't forget the lug bolts on a GLE53 are M15x1.25 which is a lot different from those M14x1.5s on other Mercedes models -- at least the ones that I have had.
Old Oct 1, 2023 | 04:22 PM
ultradmp's Avatar
AMG GLE 53
Sure. They told me they can customize the wheels which I ever choose. but the other problem is that it is hard to find the tire haha…most of online tire shop doesn’t have what I need to have with R23 or R24
