Dash Cam Wire Connection
Old Oct 13, 2023 | 06:11 AM
ultradmp's Avatar
AMG GLE 53
Hi all.
I installed Venture N5 yesterday and I connected the wire like the picture.
Can you check if I did correctly?
When the ignition is turning on, the cam also turns on normally.
But I am not sure if it is working for parking mode.
My car is 2021 GLE 53 AMG.
Old Oct 13, 2023 | 10:47 AM
wildta's Avatar
GLE 580
In your fuse diagram, what are those slots labeled as?
Old Dec 24, 2023 | 10:32 AM
ultradmp's Avatar
AMG GLE 53
I can’t read the diagram. It is very complicated to figure out
Old Dec 24, 2023 | 10:36 AM
wildta's Avatar
GLE 580
The big fuse looks correct to me, not sure about the mini fuse. What is your other device?
If the camera stays on after your ignition is off then it's correct. Just make sure you have one of those voltage detectors to cut the camera off when the car battery dips below a certain threshold so you still have enough juice to start the car.
Old Dec 24, 2023 | 01:39 PM
ultradmp's Avatar
AMG GLE 53
Yeah when ignition on camera works well but I don’t think it is working when ignition off. I need to find right spot for the small fuse
