22 GLE63s Oil Viscosity
Old Oct 5, 2024 | 09:39 AM
BanjoDude's Avatar
2022 AMG GLE63s
In looking at the manual, it appears that I can use either 0W40 or 5W40 oil that meets MB 229.5 in my 2022 GLE63s. There is no guidance, however, on when to use what. I'm accustomed to seeing a temp application chart that gives guidance. Is there a specific application for one over the other? I can get 0W40 locally, but not 5W40. The car had one oil change before I bought it (only 7k miles), and 5W40 was used for that. The indy shop I use highly recommends a 5,000 mile oil change cycle on these, so I plan to follow that.
Old Oct 5, 2024 | 05:02 PM
Carbon Dated's Avatar
2019 GLE 63S AMG, 2009 C63
Honestly, i doubt the car or you would notice any difference with either one (as long as you're using a good quality oil).
Myself, I run the 5w40. If I lived in Alaska or another extremely cold state, I'd probably consider using 0W40!
Old Oct 5, 2024 | 10:10 PM
Seawater's Avatar
Stronger than Time G63, AMG GLE63s, GMC Denali 2500
I have a G63 which has same engine as GLE63 and I ordered Mobil 1 05w-40 (European Formula) from Walmart. It meets the specs Mercedes specifies for this engine.
Old Oct 6, 2024 | 08:43 AM
RMiles's Avatar
2024 GLE 53 SUV
lf you are in a very cold area use 0w40 whose viscosity allows the oil to flow properly for cold start at around -40 degrees F. 5w40 flows correctly for cold start down to about -13 degrees F.
