Contemplating a GLE53 from Quebec
For the rest of the users, any comments on the GLE53 and what to look out for? I am looking at a used unit with low km's.
Our 2015 ML350 Bluetech has been a wonderful drive but I am thinking about modernizing a little. I will miss the fuel efficiency oft he diesel (road trips where I am getting over 1200km of range on a single tank has been amazing). Might miss the space in the old ML as I am seeing that the new unit is actually smaller for storage.
M256 inline 6 is known for disintegrating engine wire harness. Expensive if not covered by warranty.
If the plugs have been replaced at the recommended 50k MILES, the wires have likely been warranted. If not, have them inspected/replaced under warranty.
Salt, or more likely magnesium chloride, doesn't appear to harm these models.
Yes, you will be disappointed with the fuel economy. My 2015 BlueTech got around 30 mph (not kph) on the highway, my 53 gets about 23 or so. It's been an adjustment.
You might consider a 450. I was very impressed that my highway mileage hovered around 31-32. In comparison, the 4cyl GLE350 I had as a loaner for a thousand miles only got 30!
Even with 32mph, the gas tank is smaller than your 166, so the range is reduced. We plan on a range of about 500 miles per tank, highway, on our 53.
Space. The SUV is HUGE compared to your current GLE. More backseat legroom and it seems like an extra foot of cargo space.
Unless you're looking at a Coupe which is way too small - I bang my head getting in, and Yes the Coupe boot is tiny.
The chassis on the 167 is a major improvement over the 166. Stiffer, giving the suspension a better platform to work from. Resulting in better ride and handling, and overall quietness. AMG's went from harsh to supple.
The downside of the 450 is a ride floatiness, and I might actually prefer steel springs over air for that model. Your 166 is also a bit floaty, a downturn from the 164 it replaced.
The best combo of ride and handling is the AMG ARC (AMG Ride Control), active sway bars.
What I was reading was a compounding issue linked to the M256. Oil leaking from camshaft position sensors, which then wicks through the wiring harness, migrating to vital components like the ECU and O2 sensors and causing electrical failures. Not sure this is due to the bio sheath or just an issue with the engine assembly. Still researching.
Many sources, such as Consumer Reports, conflate all Mercedes engines bit they're not correct.
Unless you're looking at a Coupe which is way too small - I bang my head getting in, and Yes the boot is tiny.
As for space. Surprisingly, and disappointingly, my online research indicates that the rear storage is quite a bit smaller. I had to skip around to find dimensions as web sites appear to be all over the map. For the ML I could get most of the dimensions from the owners manual except the width without mirrors and cargo capacity. For the GLE I don't have an owners manual to verify.
Exterior and Cargo Dimensions
GLE vs MLLength 194.4" vs 189.1"
Width (without mirrors) 79.3" vs 75.8"
Width (with mirrors) 84.9" vs 84.3"
Height 70.2" vs 70.7"
Cargo capacity (2 row seats up) 33.3 cu.ft. vs 38.2 cu.ft.
Maximum cargo capacity (second row seats down) 74.9 cu.ft. vs 80.3 cu.ft.
Amazingly, over time it hasn't gotten that much larger on the outside except for length. The oddity is the interior space for storage. So I went to Edmonds and figured I would have to trust them on the interior dimensions (though they were off on exterior width for the 2015 ML saying the dimensions were without mirrors when they were actually with mirrors).
Front Seat Dimensions
GLE vs MLFront head room 40.5 in. vs 38.9 in.
Front leg room 40.3 in. vs 40.3 in.
Front shoulder room 59.3 in. vs 58.5 in.
Rear Seat Dimensions
Rear head room 36.9 in. vs 38.5 in.Rear leg room 40.9 in. vs 38.4 in.
Rear shoulder room 58.3 in. vs 58.4 in.
Basically, they added 2.5" of leg room in the back, and sloped the ceiling so there is less overhead space. This contributes to a storage compartment that is 4.9 cu ft smaller in the GLE.
The extra length of the vehicle I figure is related to the inline 6 vs the more compact V6. Even the older V8's appear to be shorter than the inline 6. In short (pardon the pun) the extra length did not end up contributing to more space in the cabin.
The rear opening is shorter floor to ceiling, so it's harder to put chairs etc. in there.
I have a two row, (the only configuration on a 53 I think) but a 3rd row loses cargo space to the folded seat. I think you also lose a spare or inflation kit, and might be stuck with Runflats.
Make sure you're comparing 2 row to 2 row, and SUV to SUV (not Coupe).
In practice I gained a huge amount of space with the 167.
All the stuff on the floor and on the various countertops went in one load, in the cargo area. More luggage in the back seat itself.
I am also careful on the 2 row to 2 row aspect. It is interesting to hear that there is more room in the non-3rd row version. With the third row I know you are forced into runlets (not a fan of) so my assumption (and attempted confirmations) was that this was the space used for the seats.
I wonder how capable the AirMatic suspension would be to perform as an air compressor. Suppose they would need to provide a long hose though.
Is that a current kit?
- Space wise, there is definitely more room in the W166 over the W167 in the back. We had ours and the 450 sitting next to each other with the hatch open and it is obvious. The floor height on the 450 is higher and the rear windows tilts in more coupe like (this was not the coupe version) than the W166. The storage space I can get over as it just makes for a bigger excuse to get a bigger roof box for the ski trips.
- The 450 was the base suspension (no AirMatic). The 53 has the AMG version of AirMatic. The 450 was on 21" all season tires and the 53 on 22" dedicated summer tires. Being that it is 4 degrees celsius (39 degrees F) the dedicated summers are not an ideal ride. That said I would say the AirMatic is still my preference over the traditional suspension.
This is now having me looking to test drive an X5. My buddy with an X5 almost fell over when I told him what I was thinking, and wants me to join him on the dark side.
there is significantly more boot space in a 167 compared to a 166. Even with the sloping roofline, the distance from 2nd row seatback to tailgate is almost a foot longer. Take a tape measure because looks can be deceiving. The opening is smaller floor to top, though - if you carry things taller than the opening (the "ceiling" is higher than the opening), you just have to plan differently.
The ride on 22's is generally awful, and they shouldn't be operated below 45*F because the tread can fracture. Plus there are very few tire options in that size. Recommend against.
Did you verify tire pressures on the test cars? I carry a tire pressure gauge when I am comparing vehicles because cars on many dealer lots are wrong, since many use the doorpost label (wrong on MBs) instead of the gas flap (correct). I'd say 50% are wrong.
It sounds like you are biased toward a BMW. Go ahead and get one. Your friend will appreciate your purchase.😄
On the BMW side, I actually really don't like the interiors or exteriors.
W166
- Width at the floor by the hatch opening: 43.5"
- Width at the top of the cargo cover: 52.5"
- Depth from bottom of the seat back to the door of the hatch: 39"
- Height of the hatch opening: 33"
- Height from the floor to the ceiling at the middle of the cargo cover: 34.5"
W166
- Width at the floor by the hatch opening: 43.5" //43.5"
- Width at the top of the cargo cover: 52.5" // 49"
- Depth from bottom of the seat back to the door of the hatch: 39" //42.5"
- Height of the hatch opening: 33" //33"
- Height from the floor to the ceiling at the middle of the cargo cover: 34.5" //36"
In bold above.
Interesting comparisons.
Thanks for taking the measures and posting.
I remembered the choke points from the times I overloaded them both.
