GLK winter tires
Go to Tire Rack, specify an '08 or '09 C350, and take you choice of dozens of possible 17" or 18" wheels that will fit the GLK....then pick any of the tire choices in the smaller sizes, and the "problem" ceases to exist.
235/60x17 is the OEM tire for the EU....that has a rolling diameter of approx 28.1". That means anything within .3" [27.8"-28.4"] of the same diameter will work fine, without causing you any significant speedo or odo problems. Thus, a 235/55x18 would be a bit taller, but not much, if you wanted to use 18's.
For snow driving, you want a narrow footprint and a higher profile - the OEM size in the 17 sure seems ideal to me, and there are good choices available in 235/60x17, both in winter and all-season tires.
Also no need to get TMPS for winter rims, as this system doesn't work in winter anyways.
Offtopic, but why SUV and why 4matic in texas? I'd be driving a RWD sports coupe over there.
Here in Canada, we do not have the TMPS system as in the US. We have a passive system using the ABS to monitor tire rotation. The assumption is that if one tire is lower in pressure than the rest of the tires, it would generate a rpm discrepancy, hence signalling an alert. The drawback is that it cannot tell you which tire is the "guilty" one. You have to check all the tires to find out. Secondly, if all tires are underinflated to the same extent, which could happen when there is a sharp drop in ambient temperature like in our Canadian winter, the system would not be activated because there is no observable discrepancy in rpm among the four tires overall.
I have installed in both my GLK and my C350 the tire pressure monitoring system from Hella. Got it from Tirerack. It works quite well with the display of the tire pressure of all four wheels in real time, stationary or on the move. I installed the display where the ashtray use to be with some minor filing down of the plastic enclosure. The warning system comes both in audible signal and visually with flashing light. You can set your own alert threshold, display color and alarm signal color. Signal of tire pressure comes from the wireless transmitter which is an integral part of the valve stem which comes in four with the monitor included in the kit. I find that it is especially useful in the winter when I do not want to get out of the car to check the tires. It gives me peace of mind with a push of the display button on the monitor. I have posted pictures in another GLK forum but will show them here again. I hope that it would offer as an option to help us Canadian drivers live through our harsh winter.
i also like the multi-use of a suv, even though it's on the smaller end. plus, i have a 105lb domerman pinchser who comes everywhere with me.
and yes my glk has 4matic, and heated seats! i will probably use the heated seats once or twice a winter. when it rains here is POURS!! there is quite alot of flooding and the roads can get somewhat slick, so i think the 4matic might help, plus i didn't want to wait for a 2wd glk.
Continental ContiCrossContact Winter 235/60R17
Further discount if I buy the tires, rims, mounting and balancing as a pre-winter special. They'll even store the four tires until winter and swap them out before the first snowfall at no extra cost.
Seems to be decent tires so I'll probably go with the package promo. Further, he told me the TPMS could be turned off for the winter if I chose not to install tire pressure sensors on the 17s. Can anyone else validate that?
Never heard of Conti winters, but I would never get winter set from a dealer. Not sure how it woks in Germany, but in US you'll pay twice as much at the stealership.
Regarding the dealership's winter tire package, unless one of the local independent tire stores runs a special closer to winter, the price is about a wash if I want the M-B 5-spoke 17" alloy wheels.
TireRack is totally out of there with an excess of $300 shipping charge for four tires and rims from the States. Somewhat less I suppose if I get M-B rims locally but I still pay the full going rate for mounting and balancing. When the M-B dealership rolls it all together in a heavily-discounted pre-winter special, it doesn't look too bad by the time I add up everything.
So it's pretty important to use the correct tires in Europe. And I'm not aware of any company making severe snow service tires larger than 17 inch sized for the GLK.
I'm trying to find where in the manual I read it, but can't at the moment....I think the reason TPMS don't work in winter is because of temperature and therefore pressure fluctuation, I guess there is enough change that would trigger TPMS all the time.
Just a guess. I haven't gone to the garage yet to get my Owner's Manual. If there's something in there, I guess I missed it.
TPMS doesn't "stop working in the winter". You may get more warning messages unless you pump up the tires the first time cold temps hit, but that's it. There are no references in the owner's manual to the system not functioning in the winter - I hate TPMS, wish it weren't there, despise the expense and complexity, but it is in response to a US legal requirement, and MUST work by law all the time - it doesn't get to take the winter off.
You can key in:
235 60 17
235 55 18
235 50 19
235 45 20
and see the differences. Specific tires may vary slightly from the calculations.
Tirerack site shows a wide range of 17 and 18 inch wheel options with 45mm offset (use the c350 model to find them.) Winter tire selection for 235 60 17, or 235 55 18 is much broader than for 19 and 20 inch wheels.
