GLK 350 Launch Control
It can be 'awakened' however by opening this little MB 'Easter Egg'. Once activated, when you want a quick stoplight start you merely hold one foot on the brake pedal - press the throttle to the floor - and when you release the brake the computer will generate max HP and shift close to redline in each gear. Will improve your 0 to 60 times by appx .4 seconds.
IF YOU PRESS ON THE BRAKE AND THROTTLE SIMULTANEOUSLY AND THE ENGINES REVS YOU HAVE FAILED TO ACTIVATE LAUNCH CONTROL. STOP - DO NOT OVER-REV YOUR ENGINE AND FOLLOW THE ACTIVATION PROCEDURE AGAIN.
To engage MB Factory Launch Control:
* Turn Key On but do not start
* Press the Accelerator Pedal three times while depressing and holding the "C"/"S" button that is next to your shift lever.
* Turn Key Off.
* Turn Key On again and depress the ESP button below the Emergency Flasher for 5 seconds, then immediately release and press the "C/S" button again.
Launch control is not activated. Have fun.
Note: All 'launch control' starts will be recorded on the MB DME control data acquisition box and stored in memory, and can be downloaded via Dealer OBD code equipment.
Insideline did report that GLK reacted very well to brake and gas pedal overlap, perhaps this "launch control" was enabled or it's just how it works on GLK.
Also not sure if I understood this correctly. If LC is on and you push brake and gas at the same time engine won't rev???
Also how does all this affect the warranty is another question.
Correct on the methodology IF you set the program up correctly.
Warranty? It could be argued that the program exists in the vehicle, therefore it cannot void it. They just mask it for the US market, they didn't remove it.
The reason I was also asking for the source is that I've been on C and C63 forums and haven't heard anybody talk about LC there. I read new E63 will have official LC.
Have you tried this new "launch control" feature does it really make difference? I'd also keep in mind that 0.4sec difference might not be the same for US cars, as the transmission might be already programmed more aggressively in non "launch" mode.
GLK forum is getting better and better
Quite frankly, not sure about this concept of LC. First time I've ever heard of it. Can't understand why simply flooring it would not achieve the same thing.
If NYCGLK is correct (and I have no reason to doubt) then power braking alone would do the job, regardless of whether or not the computer could adjust the revs.
As far as adjusting shift points to be closer to redline, most automatic transmission cars do that when you put it in any gear besides D. If a person was trying for a quick 0-60 ET, then he or she is almost certainly be going to manually shift, so the same thing will be achieved.
Therefore I seriously doubt that launch control mode is going to be good for 0.4 seconds. Unless the baseline to which this is compared is a person simply sitting at a stop sign as usual and hitting the gas with none of the usual sort of techniques as I just described.
The one thing that would help a lot would be if the computer monitored wheel spin while in launch control mode, and modulated the revs to keep the wheels just at the point of spinning so they just don't go up in smoke.
Or if launch control mode engaged a special program to control the transfer case to distribute power better to limit wheel spin. Or if the car had electronically controlled diffs (ala F1) that could be controlled "better" while in launch control mode.
I didn't see any mention of those last two points so far in the discussion, and am not that familiar with the transfer case, diffs, and the control programs to know much about those, but that seems to be where the real benefit would come in to play.
Can anyone shed more light on those?
(And thanks to drcollie, I am not bashing here, just asking more questions to educate myself - I will try this out when we get ours.)
I almost wanna say that this LC on GLK is a myth, but drcollie seems quite a car enthusiast, so I wanna believe what his is saying.
I honestly think the whole 0-60 is very arbitrary. All euro cars have longer 0-100 (0-62) times, my guess just because the measure it differently.
You read here more on what goes into testing cars here:
http://www.edmunds.com/insideline/do...ticleId=130988
and their test of GLK:
http://www.edmunds.com/insideline/do.../pageId=158004
Last point, it also all depends how tranny is programed after adapting to your driving style, how many miles car has, what type of fuel is used, temperature, elevation etc.
"Acceleration Comments: The GLK responds extremely well to being held against the brakes prior to launching, cutting a full 2/10ths from the 0-60 time. In Sport Drive, the upshifts are reasonably quick and also rather smooth and seamless. Engine note is evident, but it never sounds/feels thrashy."
Sounds like power braking works, but I would have been shocked if it didn't. I do a lot of business travel, and have had the opportunity to beat, I mean drive, a lot of different rental cars. This works wonders on pretty much all cars.
I am not familiar with Sport drive, but we pick our new GLK up at the dealer in a couple of hours, so i am looking forward to it.
I haven't taken delivery yet so I can't verify, but technically you shouldn't be able to power brake a GLK. That's because the tranny is supposed to disengage at a stop when the brakes are applied, like going into N. Once the brake is released the tranny will then reengage and creap forward like a regular automatic.
That's why in those insructions to activiate LC by drcollie, says that "if you throttle and brake simultaneously, you have failed to activate LC". I assume that trying to powerbrake without launch control will be like revving in neutral rather thank loading up the torque, as drcollie goes on to say "do not over rev your engine"
Can anyone verify on a North American GLK whether powerbraking without LC works.
