GLK 350 weight vs. C350, C350 Estate
Old Jul 17, 2009 | 01:28 AM
GadgetGLK's Avatar
GLK350
Just wondering where the extra weight of the GLK 350 vs. the C350 estate/wagon (available in Europe) is.
GLK 350 4matic = 4,036 lb/1,830 kg per. Merc pdf
C350 sedan 2wd = 3,615 lb/1,640 kg per. Merc pdf
C350 estate(wagon) 2wd = 3648 lb/1655kg
( source - http://www.carmagazine.co.uk/Drives/...ontent-block=1 )
C350 sedan 4matic = 3,792 lb/1,720 kg per. Merc pdf
Therefore a C350 Estate 4Matic would be +15kg over C350 sedan 4matic = 3825 lb/1735kg
So GLK is 211lb heavier than the C350 Estate 4matic. I wonder where that weight is?
More glass and sheet metal due to taller roof?
Old Jul 17, 2009 | 01:47 AM
mr.mbenz's Avatar
GLK 350X :0
Cool
my 2 cents...
it could be the wheels and tires as they are different size altogether.
and if you can check the gas tank size, that would be the other reason, perhaps?
If you really want to take some weight off, remove the spare tire and save about 40-50 lbs instantly!
Old Jul 17, 2009 | 01:53 AM
GadgetGLK's Avatar
GLK350
Nope. Just curious what the difference is.
Old Jul 17, 2009 | 07:23 AM
NYCGLK's Avatar
GLK 350 / Porsche 993
I'm pretty sure GLK is about 4200 pounds, which was reported by various magazines.
I'd guess it comes from more sheet metal, bigger wheels and tires, tougher suspension and frame parts (again more metal).
Old Jul 17, 2009 | 07:55 PM
GLK4MATIC's Avatar
GLK Matte Silver|MB Arts strut tower brace|MB Arts rear brace|Shaved door and bumper trim|K&N's|
Agree with all on more sheet metal. The C Class hood is much shorter (cowl height) than the GLK's so there is extra weight there, not to mention all the extra metal used for the taller doors, A pillars, B pillars etc. The GLK's suspension is much thicker and the camber arms, springs etc. are longer as well.
