GLK 4Matic - using manual mode
I believe that you push the stick to the left to downshift to lower gears 1, 2 and 3 and push the stick right to upshift to gears 4,5,6,7?
If you just downshift will it upshift automatically?
Any damage to the transmission if it's done improperly?
"To prevent the engine from overrevving, the automatic transmission does not shift down if you push the selector lever towards D- while driving at too high a speed."
"If the maximum engine speed for the shift range is reached and you continue to accelerate, the automatic transmission shifts up in order to prevent the engine from overrevving, even if the shift range is restricted."
The referenced page seems to be about the same as what's in the Owner's Manual as far as how to use Touchshift.
" Fast gear-change using the principle of repeated downshift
When the driver switches down rapidly through the gears (kickdown), the new transmission does not always select the individual gears in strict order. Instead, 7G-TRONIC will miss out a particular gear if necessary, switching from seventh gear straight down to fifth, for example, and from there directly to third. In this situation, only two gear changes are actually required – instead of the normal four – in order to accelerate quickly using kickdown.
Shift quality, meanwhile, also hits new heights. The new transmission glides through the gears extremely smoothly and yet with impressive speed. Gear-change is barely noticeable, especially in the higher gears."
There is no 7gear, it is 6 forward plus 1 reverse...
Bp
But am unable to see the D7 when I turn the gear shift to the right.
At high speeds when I turn the shift to the left, I see D5, my impression was that if it had 7 forward, then it would have been D6.
Help us understand, including the 2 reverse....
Here it is, I think that's where I got it from. One mistake I saw was about corner illumination, so some specs might differ a bit, but those would be small details.
But lets face it, the manualmatic mode is just there for people that get bored easily, it has no meaningful purpose. It doesn't help in performance (see above mentioned paragraph about it not letting you hold gears) nor does it help in improving gas mileage. It does however give the driver something to fiddle with.
Also if you are towing the M mode would be helpful to keep rmps higher that auto is programmed to do.
"Do not shift down a gear manually in order to brake.
try to avoid depressing the accelerator pedal beyond the pressure point (kickdown).
only use ranges 3, 2 or 1 for slow driving, e.g. in mountainous terrain."
And not when it is slippery. From the manual:
" ! When driving down long and steep
grades, relieve the load on the brakes by
shifting into a lower gear to use the
engine’s braking power. This helps prevent
overheating of the brakes and reduces
wear.
When using the engine’s braking power, a
drive wheel may not spin for an extended
period of time, e.g. on slippery road
surfaces. This may cause serious damage
to the drivetrain which is not covered by the
Mercedes-Benz Limited Warranty."
. No problems with the glk. Just have to be more careful parallel parking with those 20 inch wheels. Now that I have the 17's with snow tires it will be less of a problem (thanks Baby G). Had a couple of funny incidents - I thought the engine was off and couldn't understand why I couldn't lock the car - the car is so quiet when it stops!
Finally got to try out sport mode and manual shifting. I think having paddle shifters would be better because both your hands are on the steering at all times. It was still fun though and the engine sounded sweet! Stayed in 2nd and 3rd in the city, 4 and 5 on the highway. Have yet to try optimal acceleration and deceleration - see page 108 of the manual. I'll stay in comfort mode in the rain and snow.
And where did you get your snow tire package locally?
Thanks in advance!
And $1,400 before or after tax?
