Technical Issues
Old Aug 18, 2009 | 08:33 AM
BostonPrince's Avatar
GLK 4matic
Technical Issues
Hi All,
The outside of my car, just by the drivers door gets very hot...it feels like hot air is being blown to this area. It is easy to notice if you stand by the drivers door!
Anybody noticed this in their GLK...If not I think I should get it checked...
It is real hot air!!!!
Thx.
Bp
1200 miles and No problems so far...HurraH
Old Aug 18, 2009 | 09:43 AM
Miric's Avatar
2010 GLK 350
I think it's just warm air from the engine. I noticed the same think on mine. I'm not worry about it, the 3.5 is a big engine and it generates a lot of heat. Did you also notice that just after you started the engine, the radiator fan kicks in? On mine, even if the engine is cold - morning start - the radiator fan will kick in at low speed. Later on, when the engine gets hotter, the fan will spin faster to cool down the engine.
Old Aug 18, 2009 | 09:47 AM
GLK 4matic
Thx Miric, I did, but that is the only area around the car that has this hot air blowing....wish it was the passengers side!!!
Yeah I noticed the fan....But glad that the drive is very smooth with minimum noise...
Bp
Old Aug 20, 2009 | 02:11 PM
GLK 4matic
Correction to my earlier post...I have noticed this hot air blowing by the wheels on all sides...
Old Aug 20, 2009 | 04:16 PM
NYCGLK's Avatar
GLK 350 / Porsche 993
Does the gauge say engine is overheating? If not then it's normal. Parts do heat up (engine, break rotors, tires). If hot air is coming out, it's good, means it's not trapped in the engine bay.
Old Aug 20, 2009 | 05:29 PM
Baby G's Avatar
GLK 350
BP, I wouldn't be to worried about it. As long as their are no warnings you are good.
Old Aug 20, 2009 | 06:28 PM
GLK 4matic
Thanks NYCGLK and Baby G. The guage does not say it is overheating and am glad that things are fine....And thanks to you both and others in the forum for enhancing my experience.
BP
Old Aug 21, 2009 | 12:18 PM
Jaydeath's Avatar
2013 SL550, 2011 E550 Cab, 2013 E350 Sedan
BP, I suppose others have addressed this, but I just want to say it's an issue, or rather trait, that is shared in my other MBs as well. The way I look at it is, I'd rather the heat be outside the car than in it!
