Is there a PDF for the Nav
Bump control knob forward till item on top of screen menu line is higlighted, select NAV, press steering wheel voice button and say "enter destination".
The NAV lady asks you a series of questions regarding address, and you respnd "OK" to confirm. Don't say correct or it thinks you want to make a correction. That is about the only odd idiosyncracy I can think of.
The standard screen has a top bar that lists the highest level function choices, NAV, Audio, Phone etc. Large middle of screen is map or phone numbers or radio station info and the a bottom bar lists sub function choices like AM, FM etc for radio.
Back to NAV, once you respond YES to voice asking if you want to start route guidence, you can activate other functions like audio or phone and it will not interupt guidence. If you want to modify view of map or something like that, you do need to go back to NAV.
Oh, last cool thing when you are getting used system, you can always press button on dash for NAV ore Audio etc vs using contro system, if you lost in a function.
The PDF or Mannual is almost more confusing than just learning the system by trial and error.
Very Easy, Very Nice. Enjoy
